anon8380037
Correct, the device decides how much of that 2 amp to use, it will generally start out high, and come down as charge comes up, it will taper way off after the battery reaches about 95%, battery temperature also has a hugh effect on charge rate. Also, due to resistance, that 2.0 amp power supply will only be able to deliver approximately 1.8 amp to the phone.
What annoyed me about charging my two GS2 batteries was it would continue to charge apparently, thereby reducing the life of the battery if you left it on.
I found a wall charger displayed in a home chain store here which claimed to have a chip to stop charging when full. Why didn't Samsung give me that for my GS2.
On my N3 will it intelligently reduce or stop the charge do you think when full, or has battery technology moved on and it's no longer an issue.
Thanks.
"All in the Best Possible Taste" via my Note 3 on AC's app
