1. IZZY1340's Avatar
    Hello I need some major help I'm sure I can get it here. My problem is I have an Verizon galaxy note 3 but now I have it on straight talk with a brand new at&t sim. Everything works except my LTE it's on something called H+ I don't even know what that is. Can someone help with the apn setting to get LTE someone help thanx alot guys
    03-10-2014 03:38 PM
  2. kentuc794's Avatar
    If it is a Verizon phone you will not be able to get LTE on AT&T. Best you could do is root it and unlock band 4 which AT&T uses in limited areas.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    IZZY1340 likes this.
    03-10-2014 03:49 PM
  3. IZZY1340's Avatar
    Thanx bro. One more question is it a big speed difference between H+ and LTE?
    03-10-2014 04:09 PM
  4. kentuc794's Avatar
    For me not in my town. When I go to Chicago or St Louis then yes huge Speed difference.
    03-10-2014 04:18 PM
  5. IZZY1340's Avatar
    Cool so you think it's a headache to root the phone just because to change that? How difficult of a task would that be?
    03-10-2014 04:34 PM
  6. IAmSixNine's Avatar
    rooting the phone will not change the hardware.
    Your phone is physically missing the hardware to work with tmobiles network. It was designed for Verizons network instead.
    03-10-2014 04:43 PM
  7. IZZY1340's Avatar
    Oh OK thanx man
    03-10-2014 04:46 PM
  8. The Hustleman's Avatar
    Doesn't have the right bands.
    Sent from my Nexus 5 using Tapatalk 2
    03-10-2014 04:47 PM
  9. dpham00's Avatar
    If you can find somewhere where att band 4 is deployed then you should be able to get 4glte. Keep in mind that att band 4 deployment is very limited
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    03-11-2014 04:39 PM
  10. arze176's Avatar
    Just out of curiosity
    What did you use to Sim unlock the Verizon version.
    I have a t-mobile note 3 that I unlocked for straight talks AT&T Sim and I always thought h+ was like a tweaked 4G
    But Idk if straight talks Sims even support lte yet. At least the most recent one I got doesn't.
    Mine is rooted and has a custom rom and network shows 4glte maybe it supports it or its a placebo effect
    Sent from my SM-N9005 using AC Forums mobile app
    03-11-2014 10:39 PM
  11. dpham00's Avatar
    The Verizon Samsung Galaxy Note 3 is factory sim unlocked.
    arze176 likes this.
    03-12-2014 12:30 AM
  1. Thoughts on the Note 2014 Edition
    By slackerjack in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-01-2014, 09:30 PM
  2. Thoughts on UK Carriers
    By tastisnax in forum International Carriers
    Last Post: 03-28-2014, 02:11 AM
  3. Help with unbranded stock firmware
    By alexcolka in forum Samsung Galaxy S4
    Last Post: 03-16-2014, 07:25 AM
  4. App Needed
    By thatotherdude24 in forum General Help and How To
    Last Post: 03-10-2014, 03:15 PM
  5. LG Viper won't turn back on?
    By Brett Wilson3 in forum LG Viper 4G LTE
    Last Post: 03-10-2014, 03:13 PM
