Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By jim_h#AC
  • 2 Post By Gator352
    Default Battery Drain SOOOOOOOOOOOOO Bad
    Hello all, First time poster and i really need help please.
    I bought a Note 3 two weeks ago and the battery drain is so bad. I am lucky to get 8 hours out of the battery. Can anyone please help me - I have attached a screen shot below.
  2. #2
    Default Re: Battery Drain SOOOOOOOOOOOOO Bad
    If you installed Kit Kat, that'd your problem, it's having major issues with battery and Wifi
  3. #3
    Try disabling or removing whatever that music download app is (second on list). Once it's removed or disabled, reboot your phone, recharge to full power and monitor again. It looks to me like that app is the culprit.
    Yes there seems to be alot going on and I am not sure what to do
    I just deleted the MP3 downloader i had and now its gone to this:
  6. #6
    You need to leave it a while, preferably a full battery discharge/charge cycle to get any meaningful figures from your monitoring app.
    Gator352 likes this.
    Quote Originally Posted by jim_h#AC View Post
    Ah ok, well since i delted that app anyways it even seems to be charging faster....it was a handy app to have tho as you could download all MP3....any suggestions for a new one
  8. #8
    When people download apps, only keep the ones that you absolutely have to have running and/or syncing. All others should be manual refreshed. When you have many apps consistently polling for new content, it will kill your battery.
    Case in point:
    Gmail/Email set to sync when new mail arrives
    Music app open syncing to cloud
    Facebook/Twitter polling for new content every 15 minutes
    Tapatalk/forums apps consistently polling for new content (replies to new replies etc.)
    Apps to auto update
    Pinterest/instagram consistently polling for posts and new content
    These are just a few things that will kill your battery if left at those settings. Remember, the more you have open and syncing the harder your phone works.
    jim_h#AC and JellyBeanGurl like this.
  9. #9
    V J
    V J is offline
    V J's Avatar
    Posts
    Global Posts
    295 Global Posts
    It looks like you downloaded a bunch of songs on to your phone. Downloading is just as much a battery drain as using the screen, if not more as I've noticed when downloading big HD games (1GB+) from the playstore. Try using it normally (without much downloads) and see how the battery performs, if it seems normal then you know it's your downloads(or uploads) that's causing the battery drain, which is fine, you can still keep downloading but just be prepared to charge it later on or even leave it on charge preferably while your downloads are active.
  10. #10
    Had same issues.. Battery life!.. Bought a Zerolemon extended-life battery.. $39..adds thickness and weight, but the tradeoff is amazing... Three (3!!) days without having to charge.. Running video apps, audio apps, and brightness level way up still can't kill it... Best 39 bucks I've EVER spent on an accessory for ANYTHING!
    FARTGUYS. COM.... Funny!!
  11. #11
    I agree with Gator352.
    You've got to be careful as many apps (and games!) install a service in addition to the app itself. Typically, a service will run constantly in the background (possibly in a passive mode, but not necessarily) and often consume 'some' resource in the context of CPU cycles and battery power. Some will even use third party services (bluetooth, GPS etc., which will increase the resourcs needed). Some, like email apps may only initialise once every so many hours in order to check for email. Others, like live wallpapers will be running 24/7. Granted all these apps may be coded extremely well and only use a tiny fraction of your resources. At the same time, they may be memory hogs too Plus, if you've got 10 apps and widgets running, each of which uses a paltry 1% of your CPU, that's still 10% in constant use that you won't have available for other things. Not to mention the amount of battery power those 10 will use in aggragate. Yes, individually they may look ok in your battery stats graph, but you also need to consider their total usage and whether the service they provide you is worth the loss in power?
    I never use homescreen widgets these days. I know it looks great to have lots of them displaying snippets of vital info, but the trade-off (for me personally) is that I'd rather have more CPU and longer battery life. If I need to know who's posted a reply to me here, I'll quickly log on and look. It takes up a few seconds of extra resources to do it as opposed to having some app running with push notifications or polling forums every 15 minutes for those all important replies. It's not important to have this info so frequently, so I don't use an app to keep me informed.
    Of course, I'm sure a lot of you will stick to using a ton of widgets and background services, which may indeed work well for you. Each to their own
  12. #12
    tahnir's Avatar
    Posts
    Global Posts
    38 Global Posts
    Can anyone tell me what the normal battery consumption on the Note 3 device is? So if I loose about 2 % in ten minutes browsing with the auto brightness enabled is that considered much? Oh and I'm also running KitKat. Cheers guys!
  13. #13
    V J
    V J is offline
    V J's Avatar
    Posts
    Global Posts
    295 Global Posts
    Quote Originally Posted by tahnir View Post
    It sounds about normal. I find my battery drains about 1% per 5 mins in max auto brightness which would equate to about 8 hours of screen time from a full charge, which overall I think is really good for such a big screen.
  14. #14
    When on chrome battery drops every 3 Mins by 1%..but on apps it's normally about 1% every 5 Mins. I'm happy with my battery life but I never get 6 hours screen time it's normally between 4-5..i always have auto brightness on +5
  1. Replies: 22
    Last Post: 09-23-2014, 05:35 PM
  2. Battery Normal? (GSAM)
    By Blazalin in forum General Help and How To
    Last Post: 03-15-2014, 10:04 PM
  3. HTC One: Post your battery stats here!
    By dandrew68 in forum HTC One M7
    Last Post: 03-15-2014, 12:14 PM
  4. Is Airpush bad?
    By Jalopiejoe in forum Samsung Galaxy Note 3
    Last Post: 03-14-2014, 11:18 AM
  5. Note pro 12.2 battery issues
    By dentalexel in forum Samsung Galaxy Note Pro 12.2
    Last Post: 03-14-2014, 09:11 AM
