Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Like Tree3Likes
    Default Note 3: Battery averaging out to about 4 and a half hours?
    6 max of screen usage? They say it's better than the iPhone, but I got 6 and a half to 7 with notifications off and screen brightness at half.
    This is with notifications turned off, no other apps running in the background other than facebook at 15 percent (when I'm using it). Did I get a dud? All my sync services are off, no custom loaders, screen brightness is at half, powersaving mode turned on, i'm running 4.3, and I use the phone to text and browse the web.
    3-4 pictures taken throughout the day, some facebook chatting and mainly texting. GPS is also off, and the only things that are on are screen orientation and wifi (when I'm using the phone, it's shut off when I turned the phone off because it helped battery slightly). Also, apps are never running in the background and I clear the ram a few times a day. Also reset the phone once a day as well before I take off the charger.
  2. #2
    Default Re: Battery averaging out to about 4 and a half hours?
    I am kind of confused .. Your title says your battery lasts for about 4 hours but in your first sentence you talk about having 6 hours of screen on time? Confused ..
    Also I wouldn't clear your RAM as this can actually cause more battery drain. Android uses the RAM differently than Windows so it is actually good to be using it. This article explains it pretty well... RAM: What it is, how it's used, and why you shouldn't care | Android Central
    Golfdriver97 and Aquila like this.
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,703 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Could you post screenshots of your battery stats, and graph please? Take them at about 30% remaining so we can see what is going on.
  4. #4
    Default Re: Note 3: Battery averaging out to about 4 and a half hours?
    I would also recommend using gsam, which can help to better assess the situation
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  5. #5
    If you updated to KitKat, that also is a huge problem as people across the web with Notes and Nexus's are having battery issue with KK
  6. #6
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by HothTron View Post
    Not everyone has that battery drain. I've seen some actually improve on KK.
    Either way, we can't tell without screenshots
    Sent from my Galaxy S4 running SlimKat 4.4.2
  7. #7
    I think he has left the building.
    "All in the Best Possible Taste" via my Note 3 on AC's app
  8. #8
    Quote Originally Posted by UJ95x View Post
    Your a small minority then and it doesn't effect S4's, its Note 3's and Nexus's
    Learn the truth son
  9. #9
    Posts
    Global Posts
    32,703 Global Posts
    Carrier
    I am not having a problem with KK and my Nexus.
  10. #10
    Kevin OQuinn's Avatar
    AC Team Emeritus
    Posts
    Global Posts
    9,908 Global Posts
    Carrier
    Stock
    Learn the truth son
    http://i.imgur.com/k8ZPLY4.png
    http://i.imgur.com/d7cyp3B.png
    Omg no
    Definitely not the minority. You only hear about people that have problems online. Those that aren't having problems have no reason to post "things are great!".
    But for me, things are great!
    Sent from my Nexus 5 using Tapatalk
    V J and UJ95x like this.
  11. #11
    No problems here on my Nexus 5, 2013 Nexus 7, and 2012 Nexus 7, all running 4.4.2. On my N5, Android OS currently using 7% of my battery, Android System 12%. As Bill Murray said in Stripes, "That's the fact, Jack!"
    Does the Kernel usage change after reboots?
    UJ95x likes this.
  12. #12
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default
    Learn the truth son
    No, you're the one in the minority. Someone having issues is far more likely to come onto forums like this one and share their experiences with a certain upgrade, than someone who isn't.
    You don't go to a mechanic shop, see everyone else getting their car fixed and assume that everyone in the world has issues with their car.
  13. #13
    Please keep things civil.
  14. Thread Author  Thread Author    #14
ID:	107997 Click image for larger version.
ID:	107998 There's some screenshots of general usage. I get around 5 hours on a good day, and have only gotten 6 hours ONCE out of the 2 weeks I've had it. I didn't do anything different that day. I am just wondering just based on this screenshot if I should just exchange it. Only have one day. Just really have no idea how to backup anything on this phone easily without a 3 page set of instructions.
    Also I don't have time for 3rd party apps as this may be my last day to return the phone, but I made sure to take more screenshots of my battery (those were about 4 hours and around the same kinda usage with the same apps) but they got deleted on accident the other day.
  15. #15
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by tripleh3lix View Post
    Nothing out of the usual there. If your phone's brightness is on the higher side, the screen will drain the battery faster. 5 hours doesn't seem all that bad, and there's no apps using more battery than they should.
  16. Thread Author  Thread Author    #16
    My brightness is always a bit below half. Gps off at all times other than a few times a day to check into foursquare. Also how is 5 hours of usage on average is better than an iPhone, people are saying most of the newer android phones have a better battery, I'm not seeing it..
    Also yesterdays battery life with a 20 minute phone call was about 4 hours and 21 minutes. Same kinda usage.
    So no reason to take back then and all is normal? Today is my last day.
  17. #17
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Well your signal doesn't look very good so that can be draining it more than usual. I haven't seen an iPhone get more than 4 hours of screen time. I've used both a 4S and a 5 and while the idle time was great, using the phone killed the battery fairly quickly
  18. Thread Author  Thread Author    #18
    Default
    Oh wow very strange. I always got 6 to 6 and a half on a decent day on my 5s and 5. 4s had even better battery life than both. Well thanks guys, I guess this is normal. My signal averages from 2-4 bars around the house but usually on wifi
  19. #19
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    How did you see that? The iPhone only shows "usage" for battery stats, but not actual screen time on information.
  20. #20
    5 hrs screen time is a lot for any phone. I'm a moderate to heavy user and I might see 4 hrs screen time in a day occasionally. A lot more talk time but screen trumps talk in battery use. And touch the battery graph to see your signal and awake time. Might be something there.
    ATT N3
  21. #21
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by conanheath View Post
    ATT N3
    Talk uses about as much battery in my experience
  22. #22
    This is what I was going to point out. If the iPhone got 6,7,8 hours of screen on time, Mophie would not exist. Also, you do understand that this is a 5.7" full 1080p HD screen with a quad core processor??
    Sent from my SM-N900V using Tapatalk
  23. #23
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by z06mike View Post
    Yes, I do. I've seen 8+ hours of screen time on that 5.7 inch, 1080p screen
  24. #24
    Lol, I was meaning the OP!!
  25. #25
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Oh, OK. It was in the same post in which you quoted me
  1. Moto X: Third party SMS apps and Driving Mode?
    By Ccota08 in forum Moto X (2013)
    Last Post: 03-28-2014, 10:53 PM
  2. Battery Drain SOOOOOOOOOOOOO Bad
    By Obsolete01 in forum Samsung Galaxy Note 3
    Last Post: 03-18-2014, 05:15 AM
  3. Climbing Dragon - Climb to the top! Dodge the spikes!
    By davidsolar41 in forum Android Games
    Last Post: 03-14-2014, 09:37 AM
  4. Voice Search Auto Launching again and again , Mobile going to hang
    By Pushpender Ranote in forum Android 4.0 Ice Cream Sandwich
    Last Post: 03-14-2014, 01:47 AM
