1. Umair Shams's Avatar
    Recently I started to get problems of overheating and battery drain. You won't believe it but the battery drains in 4 hours on standby (with the screen off) and gets extremely hot about 52 C. Also once it switches off it won't switch on easily. I often have to wait 2-3 days for it to boot. Can anyone tell me what the problem could be?
    03-19-2014 12:26 AM
  2. wizzrah's Avatar
    Can you check to see if there are any apps running in the background? Also, try to keep battery eating things like Mobile Data, Bluetooth, and WiFi to a minimum.
    Sent from my AT&T One X running CodefireX ROM Android Version 4.4.
    03-19-2014 01:12 AM
  3. Umair Shams's Avatar
    I have no apps running. I have even done a hard reset of the phone. WiFi and blue tooth everything's switched off.
    03-19-2014 02:14 AM
  4. wizzrah's Avatar
    Sounds like a faulty battery then.
    03-19-2014 07:02 AM
  5. dpham00's Avatar
    If you bought it from a carrier then contact them and they should take care of you. If not contact samsung
    Also you can use the gsam app to see what is draining your battery
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    boudicca00 likes this.
    03-19-2014 07:43 AM
  6. boudicca00's Avatar
    To let me know when/if my system overheats, I use the app Temperature Guard Pro. To let me know if any app goes crazy and starts taking up too much cpu, I use Watchdog. I second the use of GSam Battery Monitor to know how your phone is using the battery. To see what apps are running, I use SystemPanel App.
    03-19-2014 09:46 PM
  7. swisstrader's Avatar
    Make sure it doesnt turn into toast
    03-20-2014 05:06 AM
  1. Help, messed up root and now tab is stuck on samsung Galaxy screen.
    By shaftstriker in forum Samsung Galaxy Tab 3
    Last Post: 07-22-2015, 12:20 PM
  2. Note 3: Cases that fit with the wireless battery cover
    By 12321 in forum Samsung Galaxy Note 3
    Last Post: 11-20-2014, 09:55 AM
  3. Kitkat, S3 international and SD cards
    By newandroidguy in forum Samsung Galaxy SIII I9300
    Last Post: 03-24-2014, 05:19 AM
  4. Android wear and Moto 360
    By Anon8154066 in forum General News & Discussion
    Last Post: 03-18-2014, 08:49 PM
  5. Android system draining battery
    By 7coled in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-18-2014, 07:53 PM
