1. estrellawangzii's Avatar
    I have no options on my lock screen. It only enables me to chose the security and S Cover. It only enables me to change the font size, but not the font itself. I'm wondering if this has to do with the fact that I have no sim card and I bought this phone from China but is said to be international and unlocked.
    I also don't know how to add imgs.
    03-20-2014 12:43 AM
  2. smhism's Avatar
    Did you buy it from a reputable source in China? Could it be fake? Could you post some screen shots of your settings menu?
    03-20-2014 07:00 AM
  3. anon8380037's Avatar
    You may have a SM-N9000 which has different specs, but if you have a SM-N9005 like mine or an SM-N900- you should have these settings.
    You can attach screenshots only on the Android Forums app or the Tapatalk app. I was using Tapatalk but you just need to sign up there then log in to AC. I have just started using the AC Forums app which uses the same layout but restricts you to Android Central unlike Tapatalk.
    Screenshots will save in Gallery under screenshots. Wipe any IMEI, email or personal before saving screenshot. Power+Home will click a screenshot although many use the S-Pen screenshot.
    Sent from my SM-N9005 using AC Forums mobile app
    Attached Thumbnails Problems with settings-1395321441160.jpg   Problems with settings-1395321482336.jpg   Problems with settings-1395321508551.jpg   Problems with settings-1395321538480.jpg
    03-20-2014 08:21 AM
  4. estrellawangzii's Avatar
    Yes I bought in China and that happens to be why its not working. If anyone knows hot to change the operating system that would be helpful
    03-20-2014 03:02 PM
  1. Replies: 20
    Last Post: 07-04-2015, 08:31 PM
  2. Replies: 14
    Last Post: 04-16-2014, 07:17 AM
  3. Signs of Galaxy S5 Rounded Icons on Galaxy S4 with KitKat 4.4.2
    By Manish Kohli in forum Samsung Galaxy S4
    Last Post: 03-20-2014, 07:38 AM
  4. Issues with keyboard on Galaxy S3
    By Rianna Greenfield in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-19-2014, 09:34 PM
  5. Silencing incoming notifications with volume button
    By ToxicPhreak in forum Android 4.4 KitKat
    Last Post: 03-19-2014, 06:45 PM
