03-28-2014 06:35 AM
  1. Yas112's Avatar
    Ive recently got my note 3 and im thinking of giving it back. It uses 40% overnight when im not even using it. It uses around 10% every hour generally. During the day I don't use it for 8 hours and it uses 30% !!!!! I've taken screenshots but don't know how to attach them...*
    Thanks
    Yas
    03-24-2014 12:30 PM
  2. clevin's Avatar
    Turn off background sync, turn off data
    @T-Mobile GN3
    03-24-2014 09:22 PM
  3. Amia BooMaster's Avatar
    Something is going crazy in the background. Overnight my phone my loose like, 3%??? Yeah something is wrong here.
    Sent from my BEAST Note 3 using Tapatalk
    Spencerdl and sforsyth01 like this.
    03-24-2014 09:24 PM
  4. HothTron's Avatar
    If your on the updated kitkat, that's why
    Caleb Lopez and bleuwave like this.
    03-24-2014 09:28 PM
  5. Spencerdl's Avatar
    WOW, thats a lot can you tell me what apps you have open and/or if your wifi is on......SMILE
    03-24-2014 09:31 PM
  6. Spencerdl's Avatar
    Thanks
    Yas
    Welcome to Android Central....ENJOY
    03-24-2014 09:32 PM
  7. DoGGyPlanetWoof's Avatar
    Yes me too. After kitkat upgrade battery eats it's self fast. Worst update ever.
    Sent from my SM-N900T using Tapatalk
    03-24-2014 09:43 PM
  8. z06mike's Avatar
    We need to see the screen shots first.
    Sent from my SM-N900V using Tapatalk
    Spencerdl likes this.
    03-24-2014 10:17 PM
  9. thegame161's Avatar
    Yeah post your battery usage
    03-25-2014 09:06 AM
  10. Almeuit's Avatar
    As others have said please post pictures of your battery stats .
    Sent from my T-Mobile Note 3 using AC Forums.
    03-25-2014 09:33 AM
  11. KiwiGrrl's Avatar
    I uninstalled Tumblr today cos it had suddenly started using massive amounts of battery, even after a force stop. It was at the levels you describe. Looking at your battery stats will tell you what's eating it all up.
    ... sent from the road
    03-25-2014 07:20 PM
  12. Spencerdl's Avatar
    Now with this "live" wallpaper rotating, I expect for battery drainage to be on the high side. I like the look of it though so I kinda don't mind.....SMILE
    Sent from MY BLACK G'NOTE3
    03-25-2014 08:13 PM
  13. MrScarface32's Avatar
    That's why I love my HTC One Max
    03-25-2014 09:20 PM
  14. JellyBeanGurl's Avatar
    Wow! Had no idea we can use a live wallpaper like that! Very neat!
    Sent From My Samsung Note 3
    03-25-2014 09:26 PM
  15. V J's Avatar
    @T-Mobile GN3
    Don't do this. There's something else up with your device for sure. I'm on 4.4.2 (out of the box) with 2 emails, facebook, ebay, viber, whatsapp, skype all synced 24/7 and I only lose 1% every 3 hours on standby. Other people are the same so I'd say that the typical standby battery life. Having said that, there are many people experiencing extreme battery drain after updating to 4.4.x and it sounds like you might be one of them.
    03-25-2014 11:29 PM
  16. clevin's Avatar
    why not? you already said other people has battery drains, and your suggestion is do nothing about it?
    ps, if you want to convince me your battery drained 1%/3hrs with all those apps open, post some screenshots please.
    Caleb Lopez likes this.
    03-26-2014 06:39 AM
  17. V J's Avatar
    Here you go:
ID:	109509 Click image for larger version.
ID:	109510 Click image for larger version.
    As you can see I'm actually getting more than 3 hours per 1% on standby, no charging in between. I believe others who updated to KitKat successfully reported similar increases in standby battery life. Mine came with KitKat out of the box.
    I'm sorry you took offense to me saying don't do what you said, although I need to point out that I never said "don't do anything". Like others have suggested, the OP should post some screenshots of his battery usage so we can analyze further. A 40% drop during overnight standby is extreme when I lose 3% over 9 hour's sleep.
    It's highly unlikely that turning off data and sync will solve anything when the battery drain is that high. Even if it did, if he's gonna use a monster "smartphone" like the Note 3 without data or features synced then he's better off going back to 2001 and getting a Nokia 3310. Sure he won't have internet, but his standby will last 10 times longer. Just saying.
    03-26-2014 09:10 AM
  18. Spencerdl's Avatar
    Here you go:
    Same here, I loose approx 3% per nine hours on standby, but I'm still on JellyBean......This is NOT a problem for me and meets MY satisfaction.
    V J likes this.
    03-26-2014 09:29 AM
  19. clevin's Avatar
    You are mistaken. I am just saying you really did not offer any practical things for OP to try, all you did was listing your battery drain, which really give OP no solution.
    And, since google already admitted battery drain problem in KK and is working on a patch, there is no need to claim KK is somehow "fine".
    Lastly, I meant he/she should turn off data when phone is not in use, not all the time.
    03-26-2014 12:19 PM
  20. V J's Avatar
    If you think I'm claiming that KitKat is somehow fine then you are the one mistaken. As I clearly said on my first post there are a number of people experiencing severe battery drain after updating to KitKat and pointed out that the OP might be one of such cases, as they seem pretty common. If I didn't imply it strongly enough, I was basically pointing him towards the direction of those threads (as there are a few of them) so he can see if he's experiencing the same symptoms as the others and possibly find more information on how to fix the problem.
    Also, while turning off sync and data when not in use is an acceptable battery saving practice, disabling some of the "core" features of a smartphone is not really considered a solution. I'm sure the OP would like to be able to use his device as a smartphone is meant to be used.
    03-26-2014 12:40 PM
  21. Caleb Lopez's Avatar
    You are not the only one, I am thinking about returning it and just keeping jelly bean on the new one
    03-26-2014 11:14 PM
  22. Yas112's Avatar
    Thanks for all the responses. I think its useful for me to attach the screenshots. But because im new here im not sure how. How can I attach screenshots on the app ??
    03-27-2014 06:05 PM
  23. thegame161's Avatar
    Hold on home button and switch on button on the right side at the same time
    03-28-2014 02:09 AM
  24. clevin's Avatar
    Not sure you can attach pic in the app, try doing it on a pc
    @T-Mobile GN3
    03-28-2014 06:35 AM
  1. Can you still move apps to SD card in KitKat?
    By ahawkua in forum Android 4.4 KitKat
    Last Post: 07-13-2015, 08:48 AM
  2. Switching to Moto X from iPhone 5c
    By XCalibration17 in forum Moto X (2013)
    Last Post: 03-26-2014, 10:59 AM
  3. Replies: 1
    Last Post: 03-25-2014, 09:11 AM
  4. Replies: 5
    Last Post: 03-25-2014, 07:36 AM
  5. Why didn't I receive the kit cat upgrade for note 3
    By balamurali in forum Samsung Galaxy Note 3
    Last Post: 03-24-2014, 01:28 PM
