1. sonic1519's Avatar
    Love the Note3. So i picked up a wireless charging plate and a back cover in black so
    i could take advantage of the wireless charging. Anyway with the new back cover which
    is just a tad thicker than the EOM cover i can't find a good case anywhere. all the ones i tried
    just a tad to small. the eom cases were made to fit tight so theres not a case in site.
    anyone else going through this if so how did you solve it.
    03-24-2014 08:53 PM
  2. sforsyth01's Avatar
    I have the same problem. I haven't found a solution. The UAG case is the best fit I have found and it isn't close to perfect.
    I ended up buying the S View cover that has built in wireless charging. Case and back cover in one. But I'm not 100% happy with that solution either.
    -Shawn
    Noting the world one S-Pen at a time
    anon8380037 likes this.
    03-24-2014 08:57 PM
  3. dpham00's Avatar
    The Trident Kraken ams fits decent. The only issue is that the charging flap is a little ajar.
    The caseology didn't fit
    The otterbox commuter, Fintie, and incipio dualpro inner shells fit, but the hard outer shell didn't fit.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    03-24-2014 11:26 PM
  1. Replies: 2
    Last Post: 03-26-2014, 04:44 PM
  2. WiFi connection problems and Static IP setup issue
    By MaxSplatter in forum US Cellular Galaxy SIII
    Last Post: 03-25-2014, 11:36 AM
  3. Camera problem
    By brianrdy in forum LG G2
    Last Post: 03-25-2014, 03:12 AM
  4. Syncing Problems
    By Augusta30 in forum Google Play Store
    Last Post: 03-25-2014, 03:10 AM
  5. S 3 mini battery problem
    By Steve Hall1 in forum Samsung Galaxy S3 Mini
    Last Post: 03-24-2014, 11:09 PM
