1. ChrisP1234's Avatar
    A couple of days ago I noticed my Note 3 hadn't charged as expected. I monitored this last night to find it was charging up but very slowly. Put it on with about 15% and it took about 5-6 hours to reach full charge. I'm using the USB3 wall charger it was supplied with and I've not had an issue with this until now.
    Has anyone else had an issue like this or can anyone offer a solution before I have to book it in for repair?
    Thanks
    Chris
    03-25-2014 02:39 PM
  2. VDub2174's Avatar
    I haven't come across this issue before. It the battery getting hot at all?
    03-25-2014 02:43 PM
  3. ChrisP1234's Avatar
    No not at all. I wondered if the lead was faulty meaning it was only charging though the micro usb and not that extra bit alongside. That said it's not left my bedside table so I thought it unlikely it would just break.
    03-25-2014 03:02 PM
  4. FBA's Avatar
    USB 3 and USB 2 cables charge the same way. It has nothing to do with the extra cable, but it could be two other things: cable gone bad, charger gone bad.
    I would 1st reboot with a battery remove / reinsert 1st. If that doesn't work, try another cable (USB 2), and then another charger (at least 2.1 amps) if the two other solutions fail
    USB 3 and USB 2 wall chargers will both charge your phone at the exact same speed, if both chargers are a minimum of 2.1 amp capacity.
    USB 3 cables allow higher data transfer speeds and higher charge rates (900ma) while plugged into a USB 3 computer port, but there's no impact using the a USB AC/ DC charger with a USB 3 cable. In fact, there's no such thing as a USB 3 charger, just cable and PC port.
    03-25-2014 05:36 PM
  5. ChrisP1234's Avatar
    Thanks for your help. Took the lot to the carphone warehouse and the guy there found some green stuff on the leads contact which indicates a short apparently. New lead ordered.
    03-26-2014 02:41 PM
  6. Omar El-Kateb's Avatar
    Hello Man, I am facing the same exact issue you had. Can you please tell me what to do exactly?
    06-17-2014 08:52 PM
  7. FBA's Avatar
    He changed his cable...
    anon8380037 likes this.
    06-18-2014 05:17 AM
  8. ChrisP1234's Avatar
    Look in both ends of the lead and see if there's any green residue. Apparently it's a sign of a short. Mines been fine ever since getting a new charger. Should be able to get one on warranty.
    06-18-2014 02:28 PM
  9. certifiedmoron's Avatar
    Hi Omar El-Kateb, I have been facing the same issue for past couple of days. it requires almost an hour to charge merely 1-2%. Did changing the leads or the charger worked out for you??
    Moreover, after thorough checking i still cudnt find anything in the charging jack or on the leads
    06-19-2014 12:48 AM
  10. Christopher Palumbo1's Avatar
    I am having the same problem with my Note 3. I do not understand your cell phone talk though.
    What exactly are "leads" on my cell phone?
    -Chris
    07-10-2014 06:03 PM
  11. anon8380037's Avatar
    -Chris
    Welcome to Android Central.
    It means the detachable USB cable that came with the Note 3, along with a charging plug.
    07-10-2014 06:23 PM
  12. Joebowler300's Avatar
    Green is a sign of corrosion (i.e. your charger got wet). If you are looking for extra cables, the "Amazon Basics" brand is very good. they come in all sorts of lengths too (be forewarned, and I speak from experience, 9 feet is longer than you think :-)
    07-16-2014 07:43 AM
  13. green3003's Avatar
    u didnt explained have u cleaned green stuff on phone charging port or u changed charging cable or charger ??
    can u pls explain in detail shocking to see so many user of such popular brand having this damn issue and Samsung is doing nothing but increasing prices for its product every year with much more issues.
    03-31-2015 02:06 PM
  14. jsreen's Avatar
    I have had the same issue with my note 3 the past 2-3 months. I clean the end of the cable about every 2 weeks now with a product called Caig Labs Deoxit. One of these days I'll just go out and get a new cable but this takes all of 60 seconds and has been working. I believe the poster who saw the "green" inside the cable just ended up replacing the whole thing.
    04-01-2015 03:28 PM
  15. TheRedViper's Avatar
    I recently started noticing when I plugged my Note 3 in, that the battery wasn't even increasing, or decreasing while charging. I thought it was the battery first but I had a second battery (helps a lot) and noticed it did the same. I recently read online that often its the charging cord that does this, not the battery. I found small green dots at the charging end of the USB 3 cord which means the cord has a short of some sort. This can happen on both ends of the cord. I replaced my cord and things have been working better. So change to a newer cord.
    07-15-2015 12:38 AM
  1. Note 3: best phone out?
    By Braini4c in forum Samsung Galaxy Note 3
    Last Post: 04-06-2014, 08:21 AM
  2. Note 8.0 not writing to 64gb micro SD card
    By Grigori316 in forum Samsung Galaxy Note 8.0
    Last Post: 03-27-2014, 11:53 PM
  3. Touchpal not working on note 3
    By Sharon Ng in forum Samsung Galaxy Note 3
    Last Post: 03-26-2014, 04:39 AM
  4. Password locked S Note
    By silverlininggirl in forum Samsung Galaxy Note 2
    Last Post: 03-26-2014, 02:15 AM
  5. international note 2 out of luck on fitmware update
    By Younjulius in forum Samsung Galaxy Note 2
    Last Post: 03-25-2014, 10:28 AM
