1. 4m0wagen's Avatar
    The first few days I had my n3 the battery seemed unstoppable. Over the last few days it's been seeming to drain faster during use. Other than using task manager to kill apps is there anything else that could help? I use the auto brightness and only run a few widgets. I tried an s-view case from spigen and it seemed to drain even faster.
    03-27-2014 10:02 AM
  2. clevin's Avatar
    did you upgrade to KK recently? Google buried quite some bugs there to eat up the battery.
    Other than that, killing apps is the only way to go, instead of going to app manager, install a fast reboot so you can tap an icon on the desktop to wipe everything from memory in 2 seconds.
    03-27-2014 10:11 AM
  3. 4m0wagen's Avatar
    Clevin any certain app u recommend?
    03-27-2014 10:16 AM
  4. clevin's Avatar
    I am using this one https://play.google.com/store/apps/d...tes.fastreboot
    It does cure the ginormous standby battery drain. I use it very often, whenever I exit to the desktop from apps, before putting it down.
    03-27-2014 10:19 AM
  5. thegame161's Avatar
    What's your average screen time and overall battery time?
    03-28-2014 02:10 AM
  1. AP news app not working
    By officerripley in forum General Help and How To
    Last Post: 06-13-2014, 01:27 AM
  2. Replies: 30
    Last Post: 04-11-2014, 03:59 PM
  3. HTC One (M8): Battery Life
    By ugxvibe in forum HTC One M8
    Last Post: 04-10-2014, 02:03 AM
  4. Spotify/GooglePlay songs do not play, sometimes...
    By JoshKt in forum Google Nexus 5
    Last Post: 03-29-2014, 07:38 AM
  5. Galaxy S4: Battery life
    By Yousef Amarneh in forum Samsung Galaxy S4
    Last Post: 03-28-2014, 09:18 AM
