Results 1 to 11 of 11
    Amir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default About note 3 battery drain.
    Hi there guys. Few days back I was having a really bad battery life about 4%/hour using facebook, twitter and YouTube. Now it's back to normal about 5 to 6%/hour with same usage. I didn't install any software that could have messed up the battery.
    Anyone knows about it?
    Sent from my SM-N9005 using Tapatalk
  2. #2
    Almeuit's Avatar
    Posts
    Global Posts
    23,295 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: About note 3 battery drain.
    That actually sounds good for having the screen on and using things that all require a connection.
    Sent from my T-Mobile Note 3 using AC Forums.
    Amir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I know, but wanted to know what was wrong few days back 😞
  4. #4
    thegame161's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Losing 4% an hour using the phone? I can lose 10-15% in 30 mins when using apps
  5. #5
    AndroidvsOS's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you update your phone to KitKat lately? It has been causing drain problems to many users. Something to do with camera.
    I saw a tip on the Web to install Skype which I did and fixed most of the problem. Apparently Skype overwrites some problem-causing files that come with KitKat.
    Amir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by AndroidvsOS View Post
    I didn't update to KitKat. As I have read battery consumption is bad. I regret updating my phone to MJ7.
  7. #7
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Still reading about it. Just read a post from another site saying Skype itself is the reason. Guy says his problem gone after uninstalling Skype! Another recommends removing both Skype and twitter. I will try it.
  8. #8
    anon8380037's Avatar
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    @Amir - I made sure I have taken my medication before asking - but you meant the other way around, right. Losing 4% per hour is better than 5-6%. So now you are back to 4% ph.
    As Almeuit said, I can't see that as bad. Thats 12 hours for 50 - 70%.
    Sent from my N9005 using Tapatalk Pro
    Amir likes this.
    Amir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Madd54 View Post
    You are right. 😀
    anon8380037 likes this.
  10. #10
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have Skype installed on my Note 3, and battery drain runs at .9%/ hour. I have used 18% battery in 20 hours as of now. Wherever you read what you read posted by whoever, somewhere on the Internet, it sounds like a crock of sh!t to me.
  11. #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    http://forums.androidcentral.com/sho....php?p=3591578
    You might be right, so just the same this thread might be one of those you're talking about :-)
  1. Replies: 3
    Last Post: 07-15-2014, 06:11 PM
  2. Note 2 (i317m) case
    By mjohnsoniii in forum Samsung Galaxy Note 2
    Last Post: 04-09-2014, 11:01 PM
  3. Another battery life post
    By SpankN in forum Samsung Galaxy S3
    Last Post: 04-01-2014, 08:46 PM
  4. Asus Memopad FHD 10 LTE (severe battery drain).
    By Rick Garza in forum ASUS MeMO Pad 10
    Last Post: 03-31-2014, 05:41 PM
