1. jelliebean82's Avatar
    Does anyone know why when I delete my emails from Gmail that they just come back? I will delete them, clear notifications and everything. ...only to have them pop back up over and over again....
    When I log in to my Gmail on my PC they aren't there. ...This is only happening in my phone. It's very annoying😕
    03-31-2014 08:35 AM
  2. jim_h#AC's Avatar
    Is it because your GMail app isn't syncing with Gmail before you log onto the PC version? You delete your local copies, but it doesn't sync in time to delete from the GMail server before you log onto it via the PC? That's what it seems like might be happening.
    03-31-2014 08:49 AM
  3. jelliebean82's Avatar
    Literally the emails come back over and over again....I have emails from 2 weeks ago that I have deleted from my phone over and over again and still they (along with others) pop up again. Like right now if I receive another email it will show me on my notifications and also those other emails will pop up with it :0 (
    03-31-2014 08:51 AM
  4. kentuc794's Avatar
    I had the same issue and I went into settings - applications manager and cleared the cache and data force closed it and when I went back it worked.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    03-31-2014 09:36 AM
  5. conanheath's Avatar
    If kentuc794 suggestion doesn't work, delete the Gmail account from phone and add it again. Every email sync issue I've had has been solved this way.
    ATT N3
    03-31-2014 12:21 PM
  1. Replies: 5
    Last Post: 02-10-2016, 06:19 AM
  2. problem with signchronizing
    By maxwell adugyamfi in forum HTC One X
    Last Post: 03-31-2014, 09:31 AM
  3. Samsung Galaxy S4 font problems
    By vabbs5 in forum Samsung Galaxy S4
    Last Post: 03-31-2014, 03:25 AM
  4. Replies: 0
    Last Post: 03-30-2014, 09:29 PM
