Results 1 to 4 of 4
    kdflyer's Avatar
    Posts
    Global Posts
    57 Global Posts
    Default Note 3: Help for TouchWz
    This week I noticed the help for touchwiz disappeared except for one section on the home screen. Also when I have an incoming call, the screen remains dark and I can only answer the call by pressing the on off button, get the screen on, then go to the notification panel to answer.
    Anyone have any idea of what had happened to my phone?
  2. #2
    Default Re: Note 3: Help for TouchWz
    Quote Originally Posted by kdflyer View Post
    Have you tried turning your phone off, removing the battery for one minute, then turning it back on?
    kdflyer's Avatar
    Posts
    Global Posts
    57 Global Posts
    Yes, several times
  4. #4
    Sounds like it could be a proximity sensor issue, just trying to narrow the problem down. I have no solutions. Sorry
    Sent from my SM-N900T using Tapatalk
  1. APN Settings for Unlocked Samsung Galaxy S3
    By Marinozai in forum AT&T Galaxy S3
    Last Post: 04-21-2014, 11:57 AM
  2. Question for those of you using GSam Battery Monitor
    By justlaxin13 in forum HTC One M8
    Last Post: 04-02-2014, 10:53 AM
