Results 1 to 4 of 4
    paparazzo79's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default sound in earphones quite bad,any help?
    Woow I just put and tried to play some of my fav mp3 tracks.Previously I had Galaxy S3.Then when I put earphones and let the mp3 play,the sound quality is awful.
    No bass no nothing.The sound is very poor,and I had to volume max to even hear normally.I mean huge difference compared to Galaxy S3.What's your experience with music played on this phone?Or do I need additional program or to set something?I'm running android 4.4.
  2. Thread Author  Thread Author    #2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: sound in earphones quite bad,any help?
    upss sorry.I did not plug earphones all the way.looool.my fault.
  3. #3
    B. Diddy's Avatar
    Posts
    Global Posts
    78,015 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    First, make sure the plug is pushed in all the way. If the plug is only partially in, the sound will not be normal.
    If the plug is all the way in and the sound is still poor, then maybe there is some debris (like lint) caught in the jack. Use a damp toothpick to root around, or a can of compressed air to blow it out.
    If the sound is still poor, then test it with a different pair of headphones, to make sure the problem isn't with the headphones themselves.
    EDIT: LOL, I was typing this note at the same time you were figuring out the problem. Glad it's fixed!
  4. #4
    anon8380037's Avatar
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try "small room' mode and set equaliser manually + other options to try, bass boost, etc if using the stock music player.
    I put the CSC result in the other thread.
    Sent from my SM-N9005 using Tapatalk Pro
  1. Note 3 Won't turn on.....! Help..
    By Ya Boy Vell in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 04-02-2014, 05:29 AM
  2. Do you encounter any problem after Adroid 4.4 KitKat Update?
    By Maggieooo in forum General News & Discussion
    Last Post: 04-02-2014, 03:31 AM
  3. Sound will not work, phone freezes when trying to
    By Gecks_McFlangy in forum Samsung Galaxy S4
    Last Post: 04-02-2014, 03:27 AM
  4. Cabin in the Woods Live wallpaper
    By grapps in forum Wallpapers, Ringtones, and Themes
    Last Post: 04-02-2014, 01:09 AM
  5. Need help understanding
    By shelbyloveskk in forum Inspire Rooting, ROMs, and Hacks
    Last Post: 04-02-2014, 01:01 AM
