I think I might have discovered why some have had an overheated battery.
I suspect that it boils down to the type of case being used.
I've used a Spigen Bounce since I got the phone. I've never had a hot phone, even when streaming Netflix through the hotspot.
The other day, I got the Seido that Android Central had in a daily special (the one with the kickstand and the hard shell and flexible liner). Today I was streaming Netflix and when I picked up the phone, it felt hot for the first time ever. So I checked and it was at 110?. I had never once seen a 100? temp. So I took off the case and the temp dropped to right at 100.
I suspect that anyone with a hard case is going to see those type of temps under heavy usage. It just goes with the territory. I doubt that is a "phone problem".
