1. Closingracer's Avatar
    Both are system level apps (lookout might be for t-mobile variant system app) and I closed them and still using that much. I don't have photos needed to be backed up since I haven't taken any at all today and Idk about lookout is doing
    Sent from my SM-N900T using Tapatalk
    04-03-2014 09:48 PM
  2. charlee08's Avatar
    Restart your phone
    Posted via my Note 3
    04-03-2014 10:11 PM
  3. clitrenta's Avatar
    http://img.tapatalk.com/d/14/04/04/jysy8uva.jpg
    I had the same problem with Lookout. I just disabled it. Don't see that it's that much of a benefit.
    04-04-2014 08:46 AM
  4. Closingracer's Avatar
    Meh I am paying for it so might as well use it (paying through jump which includes it)
    04-04-2014 08:58 AM
  5. Almeuit's Avatar
    Not really . It's a free app.
    https://play.google.com/store/apps/d...id=com.lookout
    Sent from my T-Mobile Note 3 using AC Forums.
    04-04-2014 09:10 AM
  6. Closingracer's Avatar
    No it isn't.... You get the premium version with jump
    04-04-2014 09:10 AM
  7. Almeuit's Avatar
    Question is are you even using the premium features or...?
    04-04-2014 09:13 AM
  8. Almeuit's Avatar
    The main reason I ask is because the premium version has a full phone backup and if it was toggled.. It could be backing up your phone in the background and draining battery. Especially since the wifi connection looks active in your screenshot .
    04-04-2014 09:24 AM
  9. Closingracer's Avatar
    I turned that off backup
    04-04-2014 09:32 AM
  10. Closingracer's Avatar
    I like the safe browsing feature and since I am paying for it why not use it
    04-04-2014 09:34 AM
  11. Lee_Bo's Avatar
    So how's it been since you rebooted your phone? I too am using the paid version (via Jump/Tmobile) but also had it when I was on Verizon. Never really had any battery issues using it. I can't speak for Dropbox because I don't use it.
    04-04-2014 09:58 AM
  12. Closingracer's Avatar
    It is OK for now but it started up this morning so Idk
    04-04-2014 10:01 AM
  13. NoteTheDate's Avatar
    Every tmobile phone comes with lookout now.
    04-04-2014 10:28 AM
  14. Closingracer's Avatar
    Yes but I am getting the premium version with jump
    04-04-2014 10:29 AM
  15. clitrenta's Avatar
    My AT&T Note 3 came with Lookout but I really don't know if it's a premium one or not. When I seen the thing with over 30% of my battery usage, I shut it down.
    wendy5001 likes this.
    04-04-2014 12:06 PM
  16. Closingracer's Avatar
    It isn't premium unless you pay for it. With t-mobile jump program it also includes mobile insurance + lookout premium
    04-04-2014 01:13 PM
  17. B. Diddy's Avatar
    Do you have scheduled scans set up? If so, turn them off. I think scheduled scans are useless if Lookout already scans an app prior to installation. An app won't suddenly become malware after being scanned as safe.
    04-04-2014 01:28 PM
  18. B. Diddy's Avatar
    The other thing to check is what percent of battery does Lookout use when the battery is down to 20-30%. Is it still high? If you just turned your phone on, the high usage you're seeing might be from an initial scheduled scan. As the day wears on, you would hopefully see the percentage go down (unless it's scheduled to scan very frequently).
    04-04-2014 01:30 PM
  19. Closingracer's Avatar
    I set it to scan weekly
    Sent from my SM-P600 using Tapatalk
    04-04-2014 03:17 PM
  1. Unbox and Walkthrough of M8 GPe edition
    By patrikr in forum Google Play edition HTC One M8
    Last Post: 04-07-2014, 11:36 AM
  2. Hot batteries
    By teleburst in forum Samsung Galaxy Note 3
    Last Post: 04-04-2014, 08:47 PM
  3. Galaxy S5: Simultaneous voice and data over 3g on Sprint?
    By eyecon82 in forum Samsung Galaxy S5
    Last Post: 04-04-2014, 10:47 AM
  4. Stop screen dimming under 5% battery?
    By FutureKix in forum Samsung Galaxy Note 3
    Last Post: 04-03-2014, 09:46 PM
  5. Replies: 1
    Last Post: 04-03-2014, 06:17 PM
