1. Tony tata's Avatar
    Driving to myrtle in july would like a car mount. Would like input on the best out there! I'm leaning towards the arkon seat rail one with the 18" flex pipe.
    Sent from my SM-N900P using AC Forums mobile app
    04-07-2014 03:53 PM
  2. IAmSixNine's Avatar
    post links too. Im looking for something and would prefer to buy from Amazon.
    Thanks
    04-07-2014 04:35 PM
  3. vpblaze's Avatar
    Check out this thread. Plenty of input here.
    Best car dock for Note 3?
    Also, try doing a search. You will find some others.
    Scribbled on my Note 3 and then translated into readable words using Tapatalk
    04-07-2014 04:51 PM
  4. FBA's Avatar
    I have 5 of these installed - in all of our vehicles.
    Samsung Galaxy S3 / S4 / Note 2 / 3 Car Dock - CraigsDocks
    They are expensive, but there's nothing even remotely close to them that you can buy anywhere. They incorporate a USB connector right into the dock, so you just slide the phone into the dock and that's it; it docks by itself. Fits with any size case on the phone as well, even a Zero Lemon. They are individually machined and built by hand; one at a time. If you want the absolute best, this is the case.
    Spencerdl likes this.
    04-07-2014 05:52 PM
  5. Spencerdl's Avatar
    Looks like a winner...on the wish list it goes. Thanks for the info
    04-07-2014 05:59 PM
  6. daves221's Avatar
    http://www.amazon.com/gp/aw/d/B007FH...cUvbUpU3562995
    For another option... Quite enjoying this one (in Otterbox commuter). Very solid mount (I use it landscape with no issues at all including bumpy roads)
    04-07-2014 09:01 PM
  7. FBA's Avatar
    I use it with Car Home ultra...can't beat that app. Turns on my bluetooth, turns off my WiFi, sets screen brightness to 100%, turns off screen timeout...and all sorts of cool things, and I don't have to press a single button; I just dock it!
    04-07-2014 09:05 PM
  8. zmann's Avatar
    2 phones later,, NOTE 2 and note 3 I still have not come across a car dock that I would consider replacing my ibolt with. Best dock out there.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    vpblaze likes this.
    04-08-2014 08:40 AM
  9. Lee_Bo's Avatar
    I went with the Arkon seat rail in both of my cars and love them:
    Works great with my Note 3 and Nexus 7 tablet.
    04-08-2014 09:17 AM
  10. w7sg's Avatar
    Just ordered :-)
    thx
    04-08-2014 11:26 AM
  11. NickinVA's Avatar
    iMagnet, every day of the week, and twice on Sunday.
    Sent from Tapatalk.
    04-09-2014 09:54 PM
  12. jim_h#AC's Avatar
    I've had three window mounts over the last few years. Every single one of them dropped off the window while I was driving and with the phone attached. Not good when you're on a motorway and the whole thing falls into the footwell! I tried wetting the sucker and various other 'fixes', but each of the three fell off more than once. So, what did I do? Started using blue tack to stick my mob to the dashboard. Been doing that for the last 18mths with my HoX and now the N3. The phone hasn't fallen a single time and it works a treat. It's a lot cheaper than those fancy shmancy cradle things and works better too. What's not to like?
    04-10-2014 06:12 AM
  13. JRDroid's Avatar
    I'm using a Clingo vent mount right now. You have to wash it every so often, but I love that it is univeral and will not block button on any phone ever (LG being a possible exception). It's biggest flaw is it does not launch any sort of car mode or car home.
    04-10-2014 06:46 AM
  14. NickinVA's Avatar
    ProClip is in your future. You won't regret it.
    Sent from Tapatalk.
    jim_h#AC likes this.
    04-12-2014 07:08 PM
  1. SD card not recognized/won't mount
    By Ed Simons in forum HTC EVO Design 4G
    Last Post: 05-16-2016, 05:11 AM
  2. Replies: 1
    Last Post: 04-07-2014, 08:02 PM
  3. i want to take many photo at the same time !!
    By waleed az in forum Samsung Galaxy S4
    Last Post: 04-07-2014, 04:47 AM
  4. iphone user wants to fix invalid package and insuffient memory errors on android phone
    By thisOSis in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 04-06-2014, 11:30 PM
  5. Kindle Fire mount
    By Griffin Schoenherr in forum Amazon Kindle Fire
    Last Post: 04-06-2014, 10:49 PM
