Results 1 to 22 of 22
    paparazzo79's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Connected to USB 3.0 still slow transfer speed,why?
    I bought USB 3.0 cable and connected my Note 3 via usb 3.0 extended cable to my usb 3.0 plug on my mainboard.
    But I still have slow transfer speed,avg 20 mb/s.Anyone got it better and how?
  2. #2
    IAmSixNine's Avatar
    Posts
    Global Posts
    3,286 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: connected to USB 3.0 still slow transfer speed,why?
    how long is the extended cable?
    Im pretty sure the longer the cable gets the slower the transfer will be.
    Thats how most electronics are. With longer cable runs you start to get higher signal loss.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by IAmSixNine View Post
    3 meters lentgh.
  4. #4
    IAmSixNine's Avatar
    Posts
    Global Posts
    3,286 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    that would be what, 9.9 feet.. So almost 10 feet of cable. Thats a pretty long run.
    Im leaning towards that being the issue. But im also hoping someone can chime in and either back me up or offer an alternative..
    Can you try a shorter cable? Just to test data speeds.
  5. #5
    Tarant's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have had USB 3.0 cables longer with no problems. I don't believe 3.0 has a recommended max length, 3 meters seems to be the common length.
    When you plug in your phone are you pulling the top down and selecting Media device (USB 3.0)? It's the third option down. Does the USB connection on the upper right of your screen shown the little USB symbol with the 3.0?
  6. #6
    IAmSixNine's Avatar
    Posts
    Global Posts
    3,286 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think you mean 1 meter is a common length.
    Thats about 3.3 feet. 3 meters is 9.9 feet..
    I have seen plain jane charging cables be about 6-8 feet long but when it comes to data cables they tend to be 3 feet or 1 meter.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Tarant View Post
    http://i6.photobucket.com/albums/y21...psvjiwxkha.png
    When I select media device (usb 3.0) note 3 is not recognized in my Windows 7.I don't see it in device list when I go to my computer.Whenever I connect it to my pc it's recognized as media device (that option is checked).
    Sorry guys,cable length is around 1.5 m.
  8. #8
    Tarant's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No, I mean 3 meters or 9.9 feet. Any longer and the system may not be able to transfer at full speed, but it should be faster than what the op is getting.
    OP, the only thing I can think of is your computer's USB 3.0 drivers are out of date, Depending on who made your computer you should be able to go to their website and download the USB 3.0 drivers or go into your device manager and manually update the USB 3.0 drivers.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    usb 3.0 works great with my external WD HDD which supports 3.0 with it's own cable.
  10. #10
    Brockly's Avatar
    Posts
    Global Posts
    21 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Was giving my dad movies (69gig) and was pushing 60 to 50
    ps. My cable was 8 inch. Was using my external hard drive cable
  11. Thread Author  Thread Author    #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I can use usb 3.0 cavble from my WD ext drive without need to worry about damaging plug in Note 3?
  12. #12
    dpham00's Avatar
    Posts
    Global Posts
    24,795 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by paparazzo79 View Post
    20mb/s us pretty slow. I get around 200mb/s or around 25MB/s. Perhaps a bad cable or something?
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  13. Thread Author  Thread Author    #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dpham00 View Post
    Just transfered 1.91 GB single file in 85 sec using samsung cable so it's approx 23MB/s. am I getting usb 3.0 speed benefits?
  14. #14
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You are. File type also has a lot to do with transfer speeds. Files that are less compressed will transfer at higher speeds. That said, remember that the transfer speeds stated are theoretic speeds, not practical. USB 3 should hit 5 gbps, but you will never see those speeds between the device and the computer. The speeds you're getting are a bit on the low side but inline with what they will be - in practice, if you're copying to an SD card in your device. I don't think you will see much faster transfer than that with this setup.
    Copying to the device memory, I get a 1GB transfer (zip file) on USB 2 - in 30 seconds. it's about 70 seconds for the same file if copying to the device's SD card. USB 3 is about 3 times faster than USB 2, in practice.
    Moving files (1000 or more) off the SD card to the computer (1.3GB @ USB 2.0 speeds) took me 3-4 minutes
  15. #15
    rustylongwood's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Also experiencing only modest speeds transferring over a USB 3.0 connection with a Galaxy S5. Enabled 3.0 connectivity, recognized on both laptop and S5. Transferring large video files on a USB 3.0 connection from a laptop with internal SATA SSD on a 3 foot cable. Speeds are a bit faster than USB 2.0, but nowhere near the supposed 10 times bump.. I'm guessing the Galaxy S5 internal memory is the limiting factor.
  16. #16
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I doubt that...
  17. #17
    radavi98's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My note 3 is connecting at 3.0 but during long copies, 3-4 gb, it stops and drops to the usb2 and I have to start the copy over. I am not sure if its the PC or the phone. If the phone sleeps during a xfer, does it pause? Is there a fix/setting to allow xfer completion while sleeping?
  18. #18
    ohbreeeezy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So does the length of the cable matters?
  19. #19
    dpham00's Avatar
    Posts
    Global Posts
    24,795 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ohbreeeezy View Post
    It could as well as quality of the cable and quality of the USB 3 port.
    Sent from my LG G Pad 8.3
  20. #20
    JimSmith94's Avatar
    Posts
    Global Posts
    740 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Freeza'sfre3 KitKat 4.4.2
    Quote Originally Posted by radavi98 View Post
    The 3.0 connection reverts to 2.0 after four minutes of inactivity. I wonder if that could be happening to you. I've read that people have trouble copying large files anyway.
  21. #21
    monicajae's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yeah i knew that...i get a steady connection, but i'm x-ferring mostly music--and i can't see any reason why it would take so long to x-fer...maybe because a good number if them ar ALAC or FLAC so they are obviously larger than mp3's...nice of me to join the conversation, hunh? anyhoo, my cord is the samsung stock and i've trouble shooted what i think is almost everything...i'm sure i missed something! it's been about 15 minutes and only five albums have xferred? my computer is state of the art hardware-and it sees my dev's as connected via correct protocol. oh and i'm transferring from pc to sd card within the phone--and i'm showing my connection as 3.0. yeah, just looked and same albums showing---does anyone think it maybe the software--oh yeah i'm using kies 3 because wjhen i do it via direct connection the music doesn;t show--and it may not display the songs for a while even though they did dl'd ? i ask becase the names of allbums shows -- yikes! i wouldn't even know how to test either. i mean. it doesn't show it like windows does
  22. #22
    bldg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Connected to USB 3.0 still slow transfer speed,why?
    From what I read, it only works on device, not the SD card. Keep that in mind when testing.
    I would cite my sources, but I don't have 10 posts yet.
    do a google
    Code:
    inurl:"galaxy-note-3-usb-3-0-file-transfer-benchmark/"
  1. app to remove pin lock
    By twenty1 in forum Samsung Galaxy Note 3
    Last Post: 04-19-2015, 10:45 PM
  2. Replies: 76
    Last Post: 04-15-2014, 05:39 PM
  3. Click date / time to add calendar event
    By Cyberdelia in forum HTC One M8
    Last Post: 04-11-2014, 02:19 PM
  4. Traveling to London
    By Vikman in forum Verizon Samsung Galaxy S4
    Last Post: 04-11-2014, 12:59 PM
  5. What kind of SIM card would I need for Straight Talk to work?
    By nekibo in forum Google Play edition HTC One M8
    Last Post: 04-08-2014, 01:14 PM
