1. Nguyenning's Avatar
    I sold a water damaged Note 3 where the screen remained black. The phone turned on, but the LCD screen was obviously damaged and just stayed black. Obviously, the buyer will restore the phone... I had a Patterned unlock screen (have to draw the pattern in order to unlock).
    Will he be able to get into all my data if he fixes the phone? Or is he going to have to hard reset it anyway to get it to work? (assuming he doesn't guess my pattern unlock security)
    04-09-2014 04:12 PM
  2. zedorda's Avatar
    It is possible.
    04-09-2014 04:25 PM
  3. Gator352's Avatar
    Your screwed!
    J/k!
    Posted via the porcelain throne.
    anon8380037 likes this.
    04-10-2014 09:26 AM
  4. z06mike's Avatar
    For the most part, he will have to reset the phone if it had a pattern lock on it. If he is a hacker, then you're screwed
    04-10-2014 10:01 AM
  5. anon8380037's Avatar
    I hope you get a definitive answer from a real techie/repairer cause it's interesting.
    I guess you tried to message the buyer through eBay and ask them to promise, like pretty please.
    As said, a reset maybe the first thing they have to do anyway. This would be of interest across AC forums, though it must have come up before.
    Sent from my SM-N9005 using Tapatalk Pro
    04-10-2014 10:17 AM
  6. TheMacs's Avatar
    As others have said, if they really want it, your information is theirs.
    Madd54 - If you don't have access to your screen, you can still push AndroidLost to your phone and wipe it remotely. Edit - so long as it has power. You can also use a really really big magnet.
    04-10-2014 12:50 PM
  7. anon8380037's Avatar
    Of course. Yes. Dingbat in London hitting own head with wooden mallet now.
    Except you would still need your own sim card to be installed I think, so it won't be of use to the OP.
    Anyway I have Device Manager set up now, rather than rely on Lookout, Samsung Dive which is probably defunct, and maybe 1 or 2 other apps I have that did similar.
    Device Manager with Google account log-in is the easiest.
    *Oh and a strong magnet huh.
    (I had shortened my post, so no one will know what you were on about. Sorry. )
    04-10-2014 01:10 PM
  1. Where's the G Pro 2?!?
    By Brian_d in forum LG G Pro 2
    Last Post: 08-25-2014, 11:06 AM
  2. I never got the KitKat update!!! HELP
    By Ninjaxxx in forum Sprint LG G2
    Last Post: 04-11-2014, 01:43 AM
  3. Data keeps cutting out for ~15 minutes at a time
    By littlebum2002 in forum General Help and How To
    Last Post: 04-11-2014, 12:49 AM
  4. Replies: 2
    Last Post: 04-09-2014, 09:55 PM
  5. Google music all access search problem
    By Bjorn Pauwels in forum General Help and How To
    Last Post: 04-09-2014, 02:58 PM
