Results 1 to 5 of 5
    Serial Fordicator's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    das bamf 3.0 rc4
    Default Going to canada to work for about 3 months
    Can I go to a carrier like telus and just get a sim card to work on my Verizon note 3. Everything I'm reading says I can.
    ΜΟΛΩΝ ΛΑΒΕ
  2. #2
    zedorda's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Going to canada to work for about 3 months
    They have a CDMA network and LTE so I would assume yes.
  3. #3
    dpham00's Avatar
    Posts
    Global Posts
    24,802 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by zedorda View Post
    You probably won't be able to use telus cdma network because the imei is not in their network. Same reason why the Verizon Note 3 won't work on Sprint.
    My understanding is that telus is sunsetting cdma soon anyway.
    To answer the op question, since telus has a game network, you should be able to use it. Looks like the Verizon Note 3 supports the same spectrum as Telus on everything but 4GLTE. I believe Telus uses b4,which the Verizon Note 3 supports with the latest update. But I wasn't able to get my note 3 to auto switch between lte and gsm when I used tmobile, though manually switching worked
    Telus Note 3 :
    4G LTE : 700MHz (Band 17) / 850MHz (Band 5) / 1900MHz (Band 2) / AWS (Band 4) / 2600MHz (Band 7) / 2100MHz (Band 1)
    4G (HSPA): 2100MHz (Band I) / 1900MHz (Band II) / 850MHz (Band V)
    2.5G (GSM): 850MHz / 900MHz / 1800MHz / 1900MHz
    Verizon Samsung Galaxy Note 3
    LTE, CDMA/1xEVDO Rev. A (800/1900 MHz)
    LTE B13/4 700/1700
    Global Network: EDGE/GSM (850/900/1800/1900), HSPA/UMTS(850/900/1900/2100)
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    das bamf 3.0 rc4
    Cool. I'll check on other carriers
    ΜΟΛΩΝ ΛΑΒΕ
  5. #5
    zedorda's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    After alittle more research Telus stopped deployment of CDMA back in 2000 and only keeps it around for legacy devices. They do support a handful of real old 2G Verizon phones but that is it.
  1. Asphalt * not working on 512 MB phone??
    By tech96 in forum The Gamer's Lounge
    Last Post: 04-11-2014, 06:09 PM
