This is so kool stopped google+ did a few tweaks Amazing now 2 full days life left.....
The battery life is pretty outstanding on the Note 3! Longest on any smart phone that I have had in the last 6 years!
Scribbled on my Note 3 and then translated into readable words using Tapatalk
I agree 100%, battery life is killer on the Note3 . I had my Note 3 for 7 months. Not only that, along with the super battery life, I carry two spare batteries..
Pure overkill..
Haha there is no such thing as over kill when it comes to batteries. I carry a 6000 mah Anker charger with me and have yet to use it with my Note 3. I would use it regularly with my Note 2 though.
Sent from my ballin Tab 3 using Tapatalk
How do you stop it?
Pure overkill..
Yeah I have two spare batteries.. Take them in my tech bag to work
Impossible, unless you root. You can however disable it.Delete the app? :
I keep the extra charger at work with the battery. Always able to drain the battery during the day then swap before leaving.. Always mobile .
Sent from my T-Mobile Note 3 using AC Forums.
Google+ is an app you uninstall
Unless you are talking about something else
Delete the app? :
I'm thinking of Google +, not something else. [removed by moderator]
