Is there any way to shut off the persistant notification that tells me what WiFi I'm logged into? I know I'm connected to Targaryen5! I named it! I'm at my house! I do not need the constant reminder.
No, there must be a setting...I will look. I just got updated to KitKat and I don't have this in my notification bar. Do you by chance have some type of App that you're using for WiFi?
By the way, since I updated to KitKat today, I have S-Voice disabled. It was disabled in Jelly Bean and I was able to enable and disable in KitKat.
EDIT: Checked my devices and can't find anywhere to turn that WiFi notification ON/OFF. There has to be something else in your device causing that issue...
I called a buddy with an S4 on KitKat just now and he doesn't see it either. Are you sure you don't have some app that's doing this? It doesn't have to be a WiFi related app. It could be some type of app that pushes notifications. I've never seen notifications like that before...
The item on that page for me, is "open network notification", and that's not it. There's nothing on that page that adds or removes network notifications. Do you have a screen capture of yours that you can post for us?
I have the option, but it does not have the. "or connected" at the end. I wonder if it is an AT&T thing that they removed that.
Perhaps, or maybe a KitKat thing? Since I'm still on JB.
I wonder if it's a carrier related option? I can't think of why you have it, and no one else seems to...
