Results 1 to 13 of 13
    Default wallpaper not sizing right.
    Lately ive decided that want to change my background. So when I do after unlocking the screen it show the whole image then quickly resizes to half the image. What am I doing wrong here?
  2. Thread Author  Thread Author    #2
    Default Re: wallpaper not sizing right.
    Let me rephrase that...When I apply the wallpaper the bottom half is all black and sized the image. Current using ZEDGE app
  4. #4
    I havent had that problem. However.. I download the wallpapers I want to use (from zedge) but I go to the gallery and set the wallpaper from there. Try that and see if it makes a difference.
  5. #5
    That's what I do. Most of my wallpapers are from Zedge. I always download them to my gallery, and set them from there on the phone settings menu. Never had a problem.
    Sent by my pink but not so fluffy Galaxy Note 3
  6. #6
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    The simplest and best way to avoid issues with your wallpaper is to ensure they are made to the exact size of the screen; 1920 x 1080. If done properly, the wallpaper should as well weigh very little; 20-30k or so for a static background.
  7. #7
    Zedge gives wallpaper only in resolution for your phone ... which is 2160x1920
  8. #8
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    That's not the correct resolution for this phone...
    Just did exactly what you guys recommend and dl from zedge then used the android setup and still only half the screen.
  10. #10
    Do you use any of the launchers???
  11. #11
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    Quote Originally Posted by kami8586 View Post
    ...and what happens when you use the stock wallpapers?
  12. Thread Author  Thread Author    #12
    I have nova launcher but currently try not using it. I did for a bit a while ago then didn't use it. And I tried using the stock wallpapers it would show up when I unlock the screen then quickly go to half size again.
  13. Thread Author  Thread Author    #13
    It seems like when I restart my phone it'll allow it to be the full screen but I know I shouldn't have to do that everytime
  1. Gear 2 not installing any apps... any ideas?
    By fliplovin in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 09-09-2015, 03:21 AM
  2. Correct Wallpaper Size M8
    By The Courier in forum HTC One M8
    Last Post: 11-04-2014, 10:20 AM
  3. Weather not updating/Calendar reminders
    By jordo487 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-09-2014, 01:27 PM
  4. Not enough storage available
    By TSLS in forum Samsung Galaxy Tab 2
    Last Post: 04-27-2014, 10:00 PM
  5. Replies: 11
    Last Post: 04-14-2014, 08:58 PM
