1. Jason Humphreys's Avatar
    Hi,
    Whatsapp had been working perfectly however now every time you press the emoticon button, instead of the list dropping down over the keyboard it now drops up and over where you type and the message history meaning you can't see what your typing... if you do a reset it goes back to normal but then starts again... very annoying...im using swift key... any ideas?
    Thanks
    04-15-2014 04:34 AM
  2. StarkillerFIN's Avatar
    Hi,
    Thanks
    Be sure to at least have the latest versions of WhatsApp and SwiftKey. I have them and for me it works normally. On Note 2 4.3, though.
    Posted via GT-N7100 Note II
    04-15-2014 12:40 PM
  3. FBA's Avatar
    I have the same setup as you OP, but I just tried the emoticons from Whatsapp and Swiftkey with no issues...how big have you made your Swiftkey keyboard?
    04-15-2014 01:02 PM
  4. Jason Humphreys's Avatar
    I have swift key on small keyboard but even if i go back to stock samsung one same issue. Ive downloaded latest whatsapp..worked fine for a few hours then back to the very annoying cover the entire message. If i do a reboot of the phone it works but I can't keep doing this every time. Love the note but I'm finding a hell of a lot of bugs coming from a HTC...
    04-15-2014 10:17 PM
  1. HTC One (M8): Camera Lens Issue
    By artofdesign in forum HTC One M8
    Last Post: 08-19-2016, 05:38 AM
  2. Phone/Contacts App Issue
    By strikeIII in forum Samsung Galaxy S5
    Last Post: 04-28-2014, 01:59 PM
  3. Warning: LG G2 Quality Issue
    By kasperkyd in forum LG G2
    Last Post: 04-19-2014, 09:46 AM
  4. [Free] Smileys for WhatsApp
    By kiwiio in forum Android Apps
    Last Post: 04-15-2014, 04:20 AM
  5. Note 3: Gets really hot while playing games
    By gladsy in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-14-2014, 09:38 PM
