1. Rubus Roo's Avatar
    Some cursory research on ebay, amazon etc leads me to the conclusion that it's going to cost me about 90 to get wireless charging to work on my Note 3!!!
    I do remember when I got my S3 ages ago that the cost put me off using it back then but I would've hoped that there would be a cheaper solution by now.
    Can anyone recommend a cheaper alternative but not so cheap it poses a fire risk!!!
    Great forum with loads to read so I'm glad I joined at last.
    04-17-2014 09:52 AM
  2. vpblaze's Avatar
    I hope you find out some info on this.
    This has been my main reason for not switching to wireless charging. The cost still seems to remain so high for less benefits. Sure it would be convenient to just put your phone down on a charger. But the longer charge time and price is turning me away right now.
    Scribbled on my Note 3 and then translated into readable words using Tapatalk
    anon8380037 likes this.
    04-17-2014 09:33 PM
  3. mavrrick's Avatar
    Yes it is like 90-100$ if you get the OEM charging kit.
    If you want to do it for less look at Amazon .com for QI receivers for the Note 3. They range from $9-15 then you can also get a cheap charger for around the same price.
    I started with the docooler set. They worked good. The added bonus is you can continue to use your normal cases.
    04-17-2014 09:48 PM
  4. Gator352's Avatar
    You can get the Note 3 OEM charging back for 35 bucks on Amazon. Then choose ANY qi charging pad you wish and have at it.
    Cover
    http://www.amazon.com/s/ref=nb_sb_ss_i_1_25?url=search-alias%3Daps&field-keywords=samsung%20wireless%20charging%20cover&sprefix=samsung+wireless+charging%2Caps%2C238
    Pad
    http://www.amazon.com/s/ref=nb_sb_ss_i_2_2?url=search-alias%3Daps&field-keywords=qi+charging+pad&sprefix=qi%2Caps%2C161&rh=i%3Aaps%2Ck%3Aqi+charging+pad
    04-18-2014 03:48 PM
  5. cammanvideo's Avatar
    Is there a wireless charging kit that will work when you have your note 3 in a Otter box case?
    04-25-2014 04:20 PM
  6. Gator352's Avatar
    This will do it !
    http://www.amazon.com/PThink-Ultra-t...cUvbUpU3608048
    04-26-2014 04:07 AM
  7. Nchaka's Avatar
    04-28-2014 10:00 PM
  8. Gator352's Avatar
    I just bought it, and it works great! My case is a thick wallet style one and it has no problem charging.
    I also this wireless charger, it doesn't come with an ac adapter. But I use the one provided with my phone.
    Amazon.com: PowerBot PB1020 Qi Enabled Wireless Charger Inductive Charging Pad Station for All Qi Standard Compatible Devices Including Samsung, iPhone, Nokia, Google, Nexus, LG, HTC and Other Smartphones with Receivers (AC Adapter Excluded. 2 x Mic
    Glad it worked out great for you! Once you go wireless, it's hard to go back using a cord....
    04-29-2014 03:35 AM
  9. dpham00's Avatar
    I got the Wireless charging back from Samsung directly for $20 with the 50 % codes floating around ,and I have lg and Nokia pads which were around $20 as well. The pads can be used for other devices later as well
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    04-29-2014 07:54 AM
  10. sforsyth01's Avatar
    Has anyone had any luck finding a case that fits with the wireless charging battery cover from Samsung on the phone? I have been trying since February and have found nothing.
    04-29-2014 07:42 PM
  11. dpham00's Avatar
    The Trident Kraken ams case fits ok other than the charging flap doesn't fully close.
    04-29-2014 08:21 PM
  12. Gator352's Avatar
    If your wanting to go the case route, I'd get a wireless charging coil that goes under the original back so ANY case would fit it.
    04-30-2014 04:35 PM
  1. Samsung Galaxy S3 won't charge
    By taylorjeann11 in forum Samsung Galaxy S3
    Last Post: 08-18-2014, 12:36 AM
  2. Charging from a 220V Outlet
    By amoga in forum Google Nexus 7 Tablet (2012)
    Last Post: 04-24-2014, 08:46 PM
  3. Charging Issue with Micro USB
    By mush10 in forum Samsung Galaxy S5
    Last Post: 04-17-2014, 02:58 PM
  4. Notification LED does not flash when phone is charging?
    By quarrymanpaul in forum HTC One M8
    Last Post: 04-16-2014, 03:22 PM
  5. Any chance of docks with wireless charging?
    By dataz722 in forum Samsung Galaxy S5 Accessories
    Last Post: 04-16-2014, 10:40 AM
