Results 1 to 2 of 2
    Michael Tung's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Note 3 battery problem. Dead wont turn on at all/ drains fast.
    Hey guys. So I dropped my Note 3 in the toilet long ago (note, i was really drunk. haha) anyway, because I was drunk, upon getting the phone, I didn't follow standard procedure (dont play with it, take out the batt, soak it in rice, etc), I just continued to use it. It still worked anyway. But as days went by, it would ONLY charge when the phone was completely drained (wouldnt charge when phone has juice in it). When I do charge it (when its dead), it would constantly vibrate nonstop. Couple of days afterwards, it would drain so fast, like 1% per minute or so with little to no usage.
    And now, it just wont charge, Ive used different cables and plugs, nada. It WOULD charge from time to time- but the quick draining would remain. I tried a new battery in a store, it worked, but when I tested the charging when the phone was off, it would vibrate again. which could be a sign that it'll mess up like my first battery.
    I have factory reseted it through settings, useless. I'll be trying the recovery mode tomorrow (out of town right now), would this work? If not, any solutions?
    thanks!
  2. #2
    eve6er69's Avatar
    Posts
    Global Posts
    6,449 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Note 3 battery problem. Dead wont turn on at all/ drains fast.
    i always recommend factory resetting a phone before taking any drastic measures. i also had a battery drain problem from something else, maybe an app but i did a factory reset and it worked great.
    if the reset doesnt work you might be looking at a done device.
  1. Ringtone volume problem - Samsung ace 3 duos - android 4.2.2
    By pamberi in forum General Help and How To
    Last Post: 07-31-2014, 01:58 PM
  2. keyboard issues with at&t m8
    By Diegoac3 in forum HTC One M8
    Last Post: 04-25-2014, 03:38 PM
  3. Replies: 5
    Last Post: 04-21-2014, 09:35 PM
  4. Battery Stops charging at 93%
    By Chayan Bahl in forum Moto G (2013)
    Last Post: 04-20-2014, 11:20 AM
  5. To sensitive Touchscreen on the egdes
    By zmsox in forum HTC One M8
    Last Post: 04-19-2014, 04:16 PM
