Results 1 to 6 of 6
    Unhappy My beloved Note 3 - problem(s) help please!
    About a week ago my Note 3 started to have serious lag issues. Worst is when I try to go into contacts. Favorite contacts take about 10-20 seconds to load and freeze if I try to swipe a contact for calling/sending a sms. I have not installed nor updated any apps, so it must a a samsung-update that caused it. It also uses A LOT more battery now, even on battery save mode it uses most of the battery within 10-12 hours as to almost two days a few weeks ago.
    Prior to this the home button started to ask what kind of mode pressing the home button should do. When uninstalling (downgrading really as you can't uninstall it) the google search app this stopped happening.
    Please help me, its hard enough being the only non-iphone user in the office, Im getting hell of a time for it not working properly.. It is a Telenor (Scandinavia) standard phone) not rooted or anything.
  2. #2
    Default Re: My beloved Note 3 - problem(s) help please!
    You could try clearing the cache. If that doesn't do it you can do a factory reset.
    Deb from my Note 3
  3. #3
    Sounds as of you have an app that's gone bad and it's messing with it.
    Posted via the porcelain throne.
  4. #4
    TheMacs's Avatar
    Posts
    Global Posts
    616 Global Posts
    Tried rebooting? Power it down, turn it back on. Or hold down the power button for a few seconds and tap restart.
  5. #5
    I noticed lately my Note 3 has had very slight lag issues that it seemed it didn't used to have. Like hitting the home button and the clock taking a split second to update and when navigating through apps having a slight delay. It's very minimal but I never noticed it doing that before (that I can remember). Any tips or answers to what it could be? Thanks.
  6. #6
    Restart the phone hold the home button then clear the ram ur done....
    Ulimate Note 3
  1. Rating something my games
    By devias in forum Android Games
    Last Post: 07-10-2014, 11:35 PM
  2. Google Image search problem
    By jools182 in forum HTC One M7
    Last Post: 05-01-2014, 04:54 PM
  3. S3 battery instant charge problem
    By serunox in forum Samsung Galaxy S3 I9300
    Last Post: 04-25-2014, 01:18 AM
  4. HTC One M8 Camera Problem!
    By MurkyAssassin in forum HTC One M8
    Last Post: 04-23-2014, 08:16 AM
  5. HTC One M8 Camera Problem!
    By MurkyAssassin in forum General Help and How To
    Last Post: 04-23-2014, 05:45 AM
