Results 1 to 21 of 21
Like Tree2Likes
  • 2 Post By vpblaze
  • 1 Post By rivencap
  • 1 Post By clitrenta
    Default A few questions about the Note 3
    I have just a couple of questions regarding my Note 3.
    1. What would happen if I put a 128 GB micro SD Card in it?
    2. I have noticed that when I'm outside and take a picture, the camera snaps very quickly and the quiality is good.. In low light it says processing. Anyway around this?
    Sent from my Samsung Galaxy Note 3... yeah, it's spectacular!
  2. #2
    Default Re: A few questions about the Note 3
    Use the highest res
    Ulimate Note 3
  3. #3
    Im not sure about 128 try it let us know jimmy
    Ulimate Note 3
  4. #4
    Quote Originally Posted by waz ahmer View Post
    Ulimate Note 3
    I'd like to hear the results too.
    Deb from my Note 3
  5. #5
    OP.
    A SanDisk 128GB will work in the Note 3. Another user a put up a thread about his experience with it and had no problems.
    With your camera, the reason it says processing is because the Smart Stabilization is still turned on. I was having the same problem. In low light conditions, it takes just a bit longer to snap a picture. Which can be a bummer! I turned off Smart Stabilization and haven't had a problem since. No more blurry pictures of my little one running around.
    Scribbled on my Note 3 and then translated into readable words using Tapatalk
  6. #6
    In other threads, people have stated the 128gb card works.
    Palm Treo line > BlackBerry line > Samsung Galaxy S line > NOW the awesome & powerful Samsung Galaxy Note 3! 😆📱😆
    dkhmwilliams likes this.
  7. #7
    For low light help on the camera, I use Camera Zoom Fx. 3rd party apps can adjust the settings a little more.
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by rivencap View Post
    Thanks. maybe I will give the 128 GB card a try in my Note 3.
    Quote Originally Posted by vpblaze View Post
    OP.
    I will try this. Thanks for the suggestion.
  10. Thread Author  Thread Author    #10
    I see that there are apps that indicate that they are installed through the app store, but some Won't Allow me to update them because it says that it isn't compatible. It's the Samsung Video Player and Samsung Hub. Says device isn't compatible even though I already have the apps installed.
    Sent from the Samsung Galaxy Note 3...yeah, it's spectacular.
  11. #11
    128gb microSDXC card definitely works. I was one of the first to get it and still working fine. Though I already filled it up.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
  12. #12
    Wow, only 45 mb free! What uses up most of your storage on the SD card?
    Sent from my ballin Tab 3 using Tapatalk
  13. #13
    Quote Originally Posted by dkhmwilliams View Post
    Are you updating those through the Samsung App Store?
  14. Thread Author  Thread Author    #14
    I don't see those two apps through the Samsung store. I was trying to update them through the Google Play store but it says that my device isn't compatible. Has anyone else's device been able to update these two apps?
  15. #15
    Like vpblaze I find Samsung hub etc in the Samsung apps not the play store. I've included a screen shot.
    Sent from my SM-N900V using AC Forums mobile app
    Attached Thumbnails Attached Thumbnails A few questions about the Note 3-1398933358267.jpg
  16. Thread Author  Thread Author    #16
    I don't see that at all in the Samsung App Store. Even when I search for it nothing comes up. I only see it in my installed apps list in Google Play. I'm not going to worry about it. I just thought I would ask.
  17. #17
    Can you get into the Samsung hub app? If so you can click menu >> settings >> auto update.
    That may work since you cannot see them in the Samsung apps app.
    What happens when you click this link?
    http://www.samsungapps.com/appquery/...uipID=SM-N900V
    This phone has a lot going on ...even after 9 months with it I'm still learning new things about it! :-)
  18. #18
    Mostly videos
  19. Thread Author  Thread Author    #19
    Quote Originally Posted by sarkycow View Post
    This is what shows up when I use your link.
  20. #20
    I love my Note 3 and wouldn't trade it for anything but as far as shooting low light pictures, I sure do miss my Lumia 1020. man oh man, the best phone for pictures out there, especially low light pics. I've taken pics in basically a pitch black room and had it come out like it was daylight. Freaky.
    anon8380037 likes this.
  21. Thread Author  Thread Author    #21
    I have gotten some good pics and video from my Note 3. no complaints there.
  1. Alarm not working all the time after getting KitKat??
    By htc evo 4g in forum Verizon Samsung Galaxy S4
    Last Post: 10-30-2015, 06:12 PM
  2. Samsung S4 mini Shuts off during the night
    By Virgil Guran in forum Samsung Galaxy S4 Mini
    Last Post: 12-22-2014, 06:46 PM
  3. Internet While Talking...Will it happen on the S5
    By phone-a-holic in forum Samsung Galaxy S5
    Last Post: 05-03-2014, 01:20 PM
  4. Can I ? Questions about Full Price Phones on Verizon
    By PolarBear8 in forum Samsung Galaxy S5
    Last Post: 04-29-2014, 09:46 AM
