1. Zacharyw70's Avatar
    Hey guys, so I just got my phone today and updated it to the latest Android version on AT&T. I read on these forums it's best to hard reset the phone after updating it but I can't figure out how to.
    I hold down the Volume+Home Button+Power and that just brings me to a menu saying "Are you sure you want to install custom firmware" blablabla. So I tried that but it opened up something called Odin and sat installing for awhile so I just reset it back to the home menu.
    04-30-2014 09:22 PM
  2. FBA's Avatar
    Volume UP button, not Volume down; that's why. The rest of your sequence is fine.
    Volume UP + Home, and then while holding those two, the Power button and then release all.
    04-30-2014 10:19 PM
  3. Zacharyw70's Avatar
    Thank you! Can't believe I missed that.
    04-30-2014 10:25 PM
  4. Golfdriver97's Avatar
    At the very least, do a cache clear after an update. But you are right. The old data from the previous OS can lead to conflicts. A cache clear, or reset, will help prevent this.
    Something I do is a cache clear once a month anyway. Helps keep my phone quick and snappy.
    Sent from my HTC One_M8 using AC Forums mobile app
    04-30-2014 11:16 PM
  5. Zacharyw70's Avatar
    Yeah it seems like every forum I've read has mentioned wiping device data after performing software updates, I just figured why not to be on the safe side.
    Unfortunately I was being stupid and forgot that so I downloaded like 20GB's worth of games and apps and then remembered I didn't update the OS yet.
    05-01-2014 12:02 AM
  6. Golfdriver97's Avatar
    Big reason is, updating the OS via an OTA is essentially flashing a new ROM, you are just doing it under the control of the carrier and OEM. Since you are flashing a new ROM, a cache wipe/reset is always suggested for a clean install.
    05-01-2014 12:07 AM
  7. Zacharyw70's Avatar
    Off hand question but I didn't want to make a new thread. Anyone know how to set Google Now as the default voice search? I originally had the option of doing it but I accidentally hint SVoice instead.
    05-01-2014 12:27 AM
  8. Golfdriver97's Avatar
    You can clear all default apps in settings>application manager>menu>reset app preferences.
    05-01-2014 12:38 AM
  9. jpr's Avatar
    You don't have to clear all your defaults just for one app. You can clear an individual default two ways. Either go to the app you set as default in the Application Manager and click Clear Defaults or use the Active Apps Manager and go to the Defaults tab to clear it.
    05-01-2014 01:39 AM
  1. S3 won't turn on after factory reset
    By ruca32 in forum AT&T Galaxy S III
    Last Post: 01-09-2017, 03:11 PM
  2. Note 3 Apps Ported to G2
    By SactoKingsFan in forum LG G2
    Last Post: 05-04-2014, 03:00 PM
  3. Replies: 8
    Last Post: 05-01-2014, 09:12 AM
  4. Galaxy Note 10.1 Touch acting up
    By Dzyann in forum Samsung Galaxy Note 10.1
    Last Post: 04-30-2014, 06:31 PM
  5. Any update on getting hancom word for the note 2014
    By Nychotxxx in forum Samsung Galaxy Note 10.1
    Last Post: 04-30-2014, 05:14 PM
