Page 1 of 3 123 LastLast
Results 1 to 25 of 59
Like Tree4Likes
    Default Best extended battery/case combo for Note 3!
    Hey guys,
    So like many of you I'm suffering from the recent update and my phone seems to be dying quicker than ever. I'm in the market for a bigger battery since I'm a big user and have huge hands to go with my huge phone. I'm considering the Zero Lemon 10000mah case combo however many people claim the case feels cheap. I'd like to get something big enough to warrant the upgrade however don't want to cheapen my device with a sub-par case. I'm currently using the Otterbox Defender so I'm already semi accustomed to large cases. Your input and advice would be greatly appreciated.
    Thanks!!!
    Alan Salem likes this.
  2. #2
    jeepmanjr's Avatar
    Posts
    Global Posts
    55 Global Posts
    Default Re: Best extended battery/case combo for Note 3!
    Well, I use the ZeroLemon 10000mah battery and hard case from time to time. Love the battery life, hate the size...but you can't have it all I guess! LOL! A lot of folks like it, but for me it's too big for every day use. And while the hard cover is somewhat of a pain to install/remove, I still use it for special occasions like when I visit family out of town or something like that and don't always have access to a charger. BTW, I removed the plastic ZL screen protector, it was giving me problems using the phone. Otherwise, I stay with the stock battery and Trident case. Good luck!
  3. #3
    I use the Anker 6400 battery and love the freedom it gives me from the charger. Seidio makes a case for their extended battery that also fits the 6400 perfectly right from the package. I have modified the Otterbox Defender so that it also works and fits like it should. I switch back and forth, so mentally it's like a new phone after the swap.
    Sent from my SM-T310 using AC Forums mobile app
    mchi5 likes this.
    I'm really looking for something to use everyday. Is the Zerolemon unpractical for that?
    I didn't see a 6400mah on anker's website. Are the Seido battery combos any good?
  5. #5
    I picked the Anker up from Amazon. I ordered it on a Saturday and had it in my hands on Monday. I also was contacted by email a couple of times by CS from Anker to make sure I was satisfied with my purchase and it was performing properly.
    Nice personal touch.
    Pegleg,
    What sei do case are you using for it? Did you need to customize it at all?
  7. #7
    dc5pat's Avatar
    Posts
    Global Posts
    60 Global Posts
    I have the hyperion 6400 battery with the seidio dilex extended case and holster. Fits perfectly. Didn't have to modify anything. Pretty sure it'll fit the the anker version
    Sent from my SM-N900V using Tapatalk
  8. #8
    dc5pat is right, the Seidio Dilex Extended case fits perfectly. The only problem with the Dilex is the silicone cover is the type that attracts dust.
  9. #9
    I hate the Zero Lemon case and consider it such a bad purchase that I am more than willing to use the phone naked unless I know that I need the extended battery and only until | get something better. l hate it for three reasons: 1) the extra size (which l could overlook were it not for the next two reasons); 2) the cheap plastic feel of the case and the terrible flaps that never close properly over the various ports (and the fact that some internal piece broke off) 3): the cheap plastic cover is constantly letting dust and moisture beneath it and into the phone.
    NOT WORTH THE COST
    Sent from my SM-N9005 using AC Forums mobile app
  10. #10
    There are really 3 pieces to theZero Lemon case: 1) an internal cage that snaps in place over the phone and which itself consists of 2 parts. This piece DOES NOT hold the battery in place: instead it just seems to hold the terrible plastic faceplate in place. This is the chassis that some small part of snapped off once when I removed it: it feels cheap and ready to break every time I touch it; 2) the battery itself which is huge and can maintain a charge with moderate use over three days; 3) the main hard plastic (but slightly rubbery) shell which has the port covers that never slide inplace flawlessly adjust feels cheap.
  11. #11
    msndrstood's Avatar
    Posts
    Carrier
    Stock JB 4.1.2
    I have both. The Anker 6400 and the Zerolemon 10,000.
    The Anker 6400 is my daily driver. It adds just enough bulk to make this skinny phone essier to grip without too much weight. I have a generic eBay extended TPU case on it and at home I keep it in a leather flip case to protect it from drops onto the hardwood floor. I am a very heavy user and can get up to 24 hours on battery and 8 hours on screen. I'm very happy with it and highly recommend it.
    I also have the Zerolemon 10,000. I use it when I know I'm going to be away from a charger for many hours like at a festival etc and I will be using the camera a lot. Uploads drain any battery, but uploading video to Dropbox just kills batteries, the ZL is great for instances like that. I also used it extensively this winter during our many blackouts due to the miserable snow and ice storms we had on the East Coast. It is a heavy brick, but I can't complain about the case, it's on par with the Otterbox Defender, in my opinion. I did remove the attached screen protector. My best time on the ZL was 32 hours on battery with 12 hours screen time.
    Either battery is worth the money. I paid $24 for the Anker on EBay ($5 for the extended TPU) and $49 for the Zerolemon with the case.
    Hope this helps you decide. 😊
    Sent via The Big, Bad, Beautiful Note 3
  12. Thread Author  Thread Author    #12
    Thanks for all the great input guys. I think I'm going to upgrade to the Anker 6400 and try to find a case I like for it. It seems nobody really utilizes the ZeroLemon full time and that's what I'm looking for is a full time battery for it. Any suggestions on the Anker 6400 case? Msunderstood, I will certainly check out the ebay tpu case. The Seido case has gotten mixed reviews so I'm trying to figure out if that's my best option.
  13. Thread Author  Thread Author    #13
    False alarm on the battery I tracked it down.
  14. Thread Author  Thread Author    #14
    It appears the Seido Dilex case is my best option for the most protection. I suppose I could have a screen protector installed and that be about as good as anything. Would you guys agree?
  15. #15
    msndrstood's Avatar
    Posts
    Carrier
    Stock JB 4.1.2
    Yes, I have a dry application screen protector. This is the one I use for both the Note 2 and Note 3. I haven't tried the tempered glass screen protectors, most people swear by them but this one works fine for me.
    http://www.amazon.com/dp/B00FDX4U1E/...cUvbUpU3634147
  16. #16
    Quote Originally Posted by robertmarkbram View Post
    There are really 3 pieces to theZero Lemon case: 1) an internal cage that snaps in place over the phone and which itself consists of 2 parts.... This is the chassis that some small part of snapped off once when I removed it: it feels cheap and ready to break every time I touch it
    And which did snap this morning as I tried to take it out.. *sigh*. Really hate this case.
  17. Thread Author  Thread Author    #17
    Lol. I'm sorry to hear that. Yeah, I think I've ruled out the ZeroLemon for sure.
    Have you guys heard of MPJ batteries? They make an 8500mah for the Note 3 that's very reasonably priced at 35 dollars and free shipping.
  18. Thread Author  Thread Author    #18
    Msunderstood,
    I saw on a thread from January you commented a little on a post discussing the MPJ battery. Heard anything additional? Someone said the back doesn't snap on so I'd need to order a different back. Might go with the Seido I heard that fits. The TPU case from Hyperion seems to have issues on the sides from what I've read thus far.
  19. #19
    Hi, I have the zero lemon and have been using it for quite a while. Its thick but the battery life is great. The case is very cheap feeling and cheap looking. It doesn't hold up to taking it off and putting it back on. Mine actually cracked from me taking it off and putting it on too many times. I contacted zero lemon and asked for a replacement part and they sent it to me. I highly recommend it if you need the battery and don't mind the size. Also, definitely recommend not removing it. Dust does get into the flaps. If you have any other questions let me know.
    Sent from my SM-N900T using AC Forums mobile app
    robertmarkbram likes this.
  20. #20
    This was the longest screen on time that I got using it.
    Attached Thumbnails Attached Thumbnails Best extended battery/case combo for Note 3!-1399363631685.jpg   Best extended battery/case combo for Note 3!-1399363640654.jpg
  21. #21
    I bought a MJP for a different phone not that long ago. It was supposed to be higher capacity but only lasted about half as long as the OEM one. I gave it several complete cycles and it still sucked. It could have been a bum battery but I wouldnt bother with them again.
  22. #22
    Rmedy21's Avatar
    Posts
    Global Posts
    470 Global Posts
    I had the anker 6400 battery with the Hyperion tpu cover case. I noticed that the battery made my phone sluggish and slow. I couldn't recommend that battery. I can recommend the Hyperion extended battery it works great.
  23. #23
    mchi5's Avatar
    Posts
    Global Posts
    861 Global Posts
    I highly recommend the Anker 6400 mAh extended battery. Unlike the post above I never experience the Note 3 becoming sluggish or slow. It doesn't seem any different than a stock battery - except it doubled the battery life!
    I went with the Anker because I didn't want a brick like the Zerolemon and this was a good compromise. Double the battery life with just a bit more weight, but not that much
    As for a case I have both the TPU case and the Seidio Dilex extended case. For overall feel and more protection the seidio is way better. It also looks better too. Unfortunately I hate the honeycomb look of the Hyperion TPU case.
    Good luck but you'll love not having to charge your note so much if you get either of the extended batteries!
    Sent from my Samsung Galaxy Note 3 via Tapatalk
  24. #24
    mchi5's Avatar
    Posts
    Global Posts
    861 Global Posts
    Quote Originally Posted by tarheel1400 View Post
    Yes I forgot to mention. If you get the Anker extended battery, Seidio dilex extended case, get a tempered glass screen protector for your phone and your phone will be fully protected. There is no issues with the tempered glass and seidio case. That's what I have and love it
  25. #25
    Quote Originally Posted by mchi5 View Post
    Are you talking about the separate purchases here? Battery, case and screen protector - or did the screen protector come with the case is something else?
  1. [GUIDE] How To Root Galxay Note 1
    By mobilecrackers in forum Samsung Galaxy Note Rooting, ROMs, & Hacks
    Last Post: 01-22-2015, 04:07 AM
  2. Replies: 3
    Last Post: 05-03-2014, 06:32 PM
  3. Neep urgent help.. Battery draining because of a wakelock
    By _pp in forum General Help and How To
    Last Post: 05-03-2014, 01:00 PM
