08-03-2014 08:57 AM
  1. Juunas's Avatar
    Hey,
    After the Kit Kat update I have been unable to dismiss my calendar alarms. When the alarm starts it shows the red x and the zzz sign. And when I pull the red x it shuts down, but after sometime it starts again. Same happening if I do it on the other place with thr grey buttons on the bottom. Only way I can get it to stop is to go to the calendar and remove the alarms for that event. Anyone else having the same problem?
    05-05-2014 03:29 AM
  2. vpblaze's Avatar
    Is this happening with new events or events that were put into the calender before the update?
    Scribbled on my Note 3 and then translated into readable words using Tapatalk
    05-05-2014 07:56 AM
  3. el_el's Avatar
    I've had the same issue, with a s view cover. Read that many others have encountered the same problem.
    05-05-2014 11:00 AM
  4. Juunas's Avatar
    The problem is with all my calendar events. And I do have the charging s view cover, but it does that also when I dismiss them on my gear or with the cover open.
    05-05-2014 01:46 PM
  5. hoivan's Avatar
    Related to this topic. The default samsung calendar displays event/alerts on the lock screen on the S5 with the X....Zzzz slider options. If you do not swipe either option, the screen never turns off - which drains the battery. How would I disable these event/alerts from showing up at all on the lock screen?
    05-08-2014 07:28 AM
  6. Miss Mandie's Avatar
    I am also having the same problem. If i try to hit the X button it disappears. I have even tried to remove the notification in the calendar event but it still keeps alerting me again and again. I haven't found a way to turn off the alarm yet. Any help would be great. Thanks.
    08-02-2014 11:07 PM
  7. Bazza1's Avatar
    Yup. Same here.
    I've even tried going into the 'desktop' version of my Calendar (in my case, my MacBook Air's Calendar) and disabling the Notification - letting it sync - but that only sometimes works, too.
    Most irritating.
    08-03-2014 08:57 AM
  1. Problems sending MMS from Galaxy S4 to iPhone
    By Brian Pierson in forum Samsung Galaxy S4
    Last Post: 11-04-2014, 10:55 PM
  2. Link2SD + EXT4 + XT303 = Problems
    By Dany Rodriguez Mendoza in forum General Help and How To
    Last Post: 06-02-2014, 09:58 PM
  3. Calendar problem
    By dart4605 in forum Android 4.4 KitKat
    Last Post: 05-15-2014, 08:51 PM
  4. Xperia L WIFI problem
    By Dissaster in forum General News & Discussion
    Last Post: 05-05-2014, 04:26 AM
  5. Problem with contacts on Moto X
    By Doug B in forum Moto X (2013)
    Last Post: 05-04-2014, 07:32 AM
