1. waz ahmer's Avatar
    Hi this has happened a few times now I come home from work and my note 3 phones wifi will not recognise my home router I have to put the password again is this a kit kat update issue
    Ulimate Note 3
    05-06-2014 09:31 AM
  2. IAmSixNine's Avatar
    im not having any issues with WiFi on my device.
    I have 2 different work WiFi routers and another in the building conference room.
    I have 2 at home. All different models, all D-Link or Netgear.. No issues..
    Perhaps if you gave us more info. LIke what router, what note 3 (at&t, TMO, international), stock or other?
    05-06-2014 04:01 PM
  3. waz ahmer's Avatar
    Hi its uk stock unlocked
    Ulimate Note 3
    05-06-2014 04:49 PM
  4. Zacharyw70's Avatar
    I'm not sure if it's related or not but go into Wifi>Menu Button>Advanced and make sure everything in there is checked off.
    I have been having issues with my phones Wifi constantly disconnecting and it being slow and choppy and after turning these options off it's improved.
    05-06-2014 10:53 PM
  5. waz ahmer's Avatar
    Hi thanks I unchecked the advanced wifi settings I hope it works thanks
    Ulimate Note 3
    05-07-2014 01:02 PM
  1. Pandora not working unless connected to wifi
    By Sara Di in forum Samsung Galaxy S5
    Last Post: 12-21-2015, 02:55 AM
  2. galaxy s3 on firmware upgrade encountered an issue???
    By Corey King in forum Samsung Galaxy S3 Rooting, ROMs, & Hacks
    Last Post: 05-09-2014, 11:32 PM
  3. Replies: 3
    Last Post: 05-07-2014, 11:07 PM
  4. Galaxy S4 Connectivity Issues
    By gatesy0093 in forum Samsung Galaxy S4 Active
    Last Post: 05-07-2014, 12:06 AM
  5. Bluetooth issue
    By officialclar in forum Samsung Galaxy Note 3
    Last Post: 05-05-2014, 10:22 PM
