1. amdroidboi's Avatar
    Does the galaxy gear drain the note 3 battery and what is saproviders its taking up my battery over night like mad
    05-11-2014 01:55 PM
  2. c1971ace's Avatar
    Dont know about the other but ive noticed that when I use my Galaxy Gear the battery does drain faster. Im guessing its because its connected via bluetooth. Also the watch face you use can dictate how much battery life is used too.
    05-11-2014 07:02 PM
  3. emad1995's Avatar
    Over night my battery drains 4% in a span of 7-8 hours; it's connected to my gear the entire time. Basically no, it doesn't drain battery, and if it does, it's so miniscule that it's negligible
    amdroidboi likes this.
    05-11-2014 07:31 PM
  4. amdroidboi's Avatar
    Ive just woke up my batter last night was on 86% now its on 49 i tirned of blue tooth but its saying saproviders took 17%
    Jesus Heidari likes this.
    05-12-2014 12:37 AM
  5. amdroidboi's Avatar
    Hey guys look saproviders what is it
    Attached Thumbnails galaxy gear battery drain-screenshot_2014-05-12-06-38-36.jpg
    05-12-2014 12:39 AM
  6. amdroidboi's Avatar
    Hey man have u seen my pic im confused with this
    05-12-2014 10:39 AM
  7. emad1995's Avatar
    I don't know what that is but I don't get it at all and I have gear connected 24/7. My battery life is great
    Attached Thumbnails galaxy gear battery drain-screenshot_2014-04-22-14-34-49.jpg   galaxy gear battery drain-screenshot_2014-04-22-14-34-53.jpg
    05-12-2014 08:15 PM
  8. amdroidboi's Avatar
    Hey thankyou for your help anyway man i think i sorted out the situation i wiped my gear and now my phone battery is great
    05-13-2014 12:42 AM
  9. floridarick's Avatar
    Don't know what saproviders is. I defiantly don't have that. It may be an app you downloaded............
    My drain from my GG is very little if anything at all, Just like any other bluetooth device.
    I
    05-13-2014 09:31 AM
  10. amdroidboi's Avatar
    Hey guys i wiped my gear and now my battery doesnt even drain anymore yess
    05-13-2014 10:28 AM
  11. Scottflorida's Avatar
    I
    I have this problem after hear Manager update to 1.7.052101. Before update no problems at all. See if you are on that update. If not I would recommend to wait. Saproviders is second most battery drain after last update.
    05-29-2014 07:35 PM
  12. Scottflorida's Avatar
    I just reverted back to the previous 1.6 version of gear Manager.
    If interested delete your gear Manager app and then go to
    https://www.mediafire.com/folder/e7h...#p65gtgol7135e
    And download 1.6 version.
    05-31-2014 05:30 PM
  13. dreamur's Avatar
    I downloaded the recent upgrade on my gear 2 and the battery life significantly reduced from 3 days to <24 hours! I switched off bluetooth and somehow it improved to 1.5 days. Something with the latest upgrade is causing my Note 2 to constantly ping the gear2 watch.<
    Sent from my GT-N7100 using Tapatalk
    06-10-2014 11:42 AM
  14. dreamur's Avatar
    Upgraded GM to 2.1 still heavy battery drain.
    06-11-2014 11:51 AM
  15. dreamur's Avatar
    Fixed the battery problem by deleting and reinstalling google account. Apparently there is a conflict with the gmail phone book causing the contact sync to take forever thus draining the battery.
    06-29-2014 06:38 AM
  16. Roberto Rios Hernandez's Avatar
    Hi,
    I have battery drain problem on my gear 2, even thought my galaxy note 3 is fine, the gear only lasts 8 to 10 hours with bluetooth always on and most notifications on.
    07-19-2014 08:51 PM
  17. Roberto Rios Hernandez's Avatar
    sounds interesting...I will try that..thanks
    07-19-2014 08:55 PM
  18. dreamur's Avatar
    After reinstalling all my contacts, my gear 2 is eating up 1.5% every hour so that should give me ~3 days worth of battery life for each full charge.
    07-23-2014 11:42 PM
  1. Replies: 2
    Last Post: 04-25-2015, 01:42 AM
  2. Galaxy S4 Dropped in Water - PLEASE HELP!!
    By Fabrizzio Migone in forum Samsung Galaxy S4
    Last Post: 06-02-2014, 08:42 AM
  3. Galaxy S3 change to AT&T firmware
    By tics01 in forum AT&T Galaxy S III
    Last Post: 05-19-2014, 06:26 PM
  4. Samsung Galaxy tab 2 does not charge when powered On
    By glenmaxi in forum Samsung Galaxy Tab 2
    Last Post: 05-11-2014, 03:16 PM
  5. Galaxy S4 Fast Encryption Option?
    By android_freak1 in forum General Help and How To
    Last Post: 05-11-2014, 10:09 AM
