Results 1 to 6 of 6
    Unhappy Samsung Galaxy Note III Charging Issues
    So I believe something similar has probably been posted a couple times, but I'd still like to have an answer to my specific problem, I'm greedy like that lol. Anyway, I have the Note III, it's barely 2 months old, and recently, it hasn't been charging very well. 3 days ago it started charging sporadically with the included house charger, aka will charge for a minute, then say it's not charging, then charging again, then not, etc, etc, it actually ends up losing charge over time instead of just slowly gaining. The included charge is (i believe) a USB 3.0, and that's what I'm having the issues with. Phone has never been dropped, no water damage, has been in a case the whole time, the charger hasn't been in any awkward angles or coiled up at all, so I don't think the charger is what's damaged. It might be though, because my old Android charger that I have in my car (micro USB) does still charge the phone, not very fast, but I think that's just because it's a low amp car charger. Any help would be greatly appreciated, as I JUST got the phone and would be pretty upset if I had to get it replaced already.
    PS it actually degrades in charged % fairly fast, plugged it in yesterday with 15%, after about an hour of not being touched at all, screen brightness all the way down, all apps killed, etc it was down to 5%. Even turning the phone off while it's charging doesn't help, it just doesn't degrade that way, but doesn't do any actual charging.
  2. #2
    Default Re: Samsung Galaxy Note III Charging Issues
    Well just to be clear a normal batery charge should last just over a day with 4-5 hours of screen time so next time this happens open the battery settings and take screen shots before you charge of the hours it has stayed and the screen time and post it here to give a more exact answer
    Sent from my SM-N900 using Tapatalk
  3. #3
    For the OP, same thing started happening with mine a few days ago. Thanks for the post.
    In my case though neither charging cable wants to stay plugged in. They fall out constantly.
    Deb from my Note 3
  4. #4
    You can use a toothbrush to clean the charger contacts. Try to pull the battery. If it does not work, call Samsung or the manufacturer for a replacement charger
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    Nvm, I went to the AT&T store and told them about it, they just gave me a new charger and so far it seems to be working just fine, so I guess it was just a charger issue.
    Thank you for all your help though. I did try the battery pull and cleaning the contacts with canned air and a toothbrush though.
  1. my Samsung galaxy s3 battery drains very faster than expected
    By amoledsucks in forum Samsung Galaxy S3
    Last Post: 01-30-2015, 08:36 AM
  2. How do I fix the Proximity Sensor issue?
    By mosesx in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 06-26-2014, 04:18 PM
  3. New Software Update for Note 3 on Verizon Software Update Assistant. KitKat?
    By jeremy81 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-16-2014, 02:35 AM
  4. [HELP] Samsung Galaxy S4 Mtk
    By Artistu in forum Samsung Galaxy S4
    Last Post: 05-15-2014, 05:26 PM
  5. Deleting Photos from Galaxy note 2
    By Daftbat21 in forum General Help and How To
    Last Post: 05-12-2014, 06:48 AM
