Results 1 to 14 of 14
Like Tree4Likes
  • 1 Post By Rmedy21
  • 1 Post By jpr
  • 1 Post By anon8380037
  • 1 Post By jpr
  • 2 Post By Rmedy21
  • 1 Post By waz ahmer
    waz ahmer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default IR Blaster does not work
    Hi all before all you start saying this and that yes I have a d8000 series samsung led 3d tv and yes the htc m7 ir blaster worked fine on it but it does not recognise it on my note 3 strange cos its same make
    Ulimate Note 3
  2. #2
    anon8380037's Avatar
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: IR Blaster does not work
    I don't know if its different for a Samsung to Samsung, but did you try the codes for Samsung in Watch On to turn the tv on. I could only get a code to turn my Panasonic Off, though it said On.
  3. #3
    Rmedy21's Avatar
    Posts
    Global Posts
    470 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If I does not work for your television you have to send an email to the company that handles watch on app. Eventual they will get back to you with some information
    anon8380037 likes this.
  4. #4
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Peel never got back to me in the 2 weeks it took my brain to figure trying it the opposite way to the instructions. Maybe they treat Samsung tv codes as any other.
  5. #5
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by waz ahmer View Post
    Ulimate Note 3
    You didn't give much information here. Does the IR blaster not work with any device or just this one TV? What app are you using on your phone to emit the IR. I have no problem with my IR blaster and Samsung TV myself but it's not clear from what you said if you are talking about a hardware problem or a software problem. There are many IR apps the Play Store and there is a Samsung IR Universal Remote app among them.
    waz ahmer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Im using whats on stock app
    Ulimate Note 3
    waz ahmer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I mean watch on
    Ulimate Note 3
  8. #8
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sooo did you just point it at the tv? or did you go to add device/tv - make - try first code or different codes to turn your d8000 on so the tv is recognised?
    zmann likes this.
  9. #9
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I mean watch on
    Ulimate Note 3
    You still didn't say if it is working with other devices or if you've even tried other devices. Do you see the blue LED light up when you press the buttons? Are you pointing it at the TV correctly? The IR transmitter is on the top of the phone.
    Then there is the question Madd54 asked. I first added the wrong Samsung TV code for my TV and it worked to change channels up and down and volume but if I wanted to input channel numbers it would not work properly. Did you go through all the codes?
    If you are still having a problem I would really suggest trying the app I mentioned. It is not the prettiest interface but it has a ton of codes and the dev will personally help you with codes. So if you can't get it to work with your TV, that is one of your best bets.
  10. #10
    Rmedy21's Avatar
    Posts
    Global Posts
    470 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's not your television or the Ir blaster. Apparently peel does not have the codes updated for your television.
    zmann and anon8380037 like this.
  11. Thread Author  Thread Author    #11
    waz ahmer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes I get the blue light I am chosing and doing as it says no joy
    Ulimate Note 3
  12. #12
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you agreed to the 'basic info' privacy policy, entered your age range and gender, then it probably is as Rmedy21 said and Peel haven't updated the code for your model, which may be Samsungs fault. Which is odd, I'll admit.
    Use the app to send them a query, on both forms. I would say you will be contacting Samsung CS as you have a top line 2011/d? TV and are not happy.
    Sent from my N9005 using Tapatalk Pro
  13. Thread Author  Thread Author    #13
    waz ahmer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    All you guys have been a great help thanks ever so much I have sent peel a email
    Ulimate Note 3
  14. #14
    miniandroid's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There are so many devices in the market today, no database can be completely up to date at any time. Your best bet is to contact their support to add the IR remote codes.
    There is a ZappIR remote app on Google Play Store that has over 700,000 devices in their database. Worth to try out their free trial version.
    Quote Originally Posted by jpr View Post
  1. Text not going out after kitkat?
    By jgraves1107 in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-15-2014, 08:21 PM
  2. Emoji's not working
    By avester in forum Samsung Galaxy S4
    Last Post: 05-14-2014, 04:14 PM
