Results 1 to 4 of 4
    academy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy Note 3: Memory card folders help please
    Hi all,
    I never used to use a memory card with my note until recently. I bought a 64g one, popped it in and thought I had the right idea moving all my photos, videos, fils etc across. I foolishly didn't realise it wouldn't move across in their folders, I now have everything jumbled all in together!
    I know I'm gonna have to spend time sorting it out, but how do I get things to go where they should next time I add something? For instance if I save a phot from twitter or Facebook, how can I get it into the appropriate folder in the Sd card? Do I need to move the app itself (or the part of the app that can move) on to the Sd card to do this?
    Any help would be great
    Thanks
  2. #2
    lterry913's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy Note 3: Memory card folders help please
    Quote Originally Posted by academy View Post
    Hi all,
    Thanks
    I think the easiest way to do this would be to hook the phone to your pc and create new folders there as you move the items...just be aware if you move things to an external sd and not COPY them so there is an original on the internal sd, you may not be able to find them on phone...for example some people who move photos from stock gallery to sd are not being able to access those photos from phone gallery.
    Es file explore will let you move and create new folders on external sd, but if you try to rename the original file, the phone may not recognize it.
    academy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the advice, will give it a go
    Sent from my SM-N9005 using Tapatalk
  4. #4
    emad1995's Avatar
    Posts
    Global Posts
    683 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You have to copy them one folder at a time, that way everything will copy over in their respective folders
  1. Will Google Wallet Tap and Pay ever function on the Verizon Note 3?
    By jim2112 in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-11-2015, 10:49 AM
  2. Galaxy Y battery discharging very fast
    By whizclips in forum General Help and How To
    Last Post: 04-15-2015, 12:32 PM
  3. Sprint Galaxy Note 3: My original USB isn't working!! help!!
    By Dawnae in forum Sprint Samsung Galaxy Note 3
    Last Post: 06-04-2014, 09:17 AM
  4. note 3 user needs advice on how to root!!!!!
    By Losonoso in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 05-18-2014, 04:45 PM
  5. Replies: 1
    Last Post: 05-18-2014, 10:19 AM
