Results 1 to 6 of 6
    dpham00's Avatar
    Posts
    Global Posts
    24,790 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Battery jumps 16% after I did a battery pull
    I did a battery pull and battery percentage went up 16%. This wasn't the first time this happened either. Anyone else have this happen?
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
  2. #2
    FanOfAnything's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery jumps 16% after I did a battery pull
    I just did it to check and mine lowered mine now is at 13%
    Posted from my note 3 :3
  3. #3
    sarkycow's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dpham00 View Post
    http://img.tapatalk.com/d/14/05/20/jyrymyty.jpg
    Like the poster before me I gave it a go to see what would happen. Mine also dropped (not majorly) from 62% to 60%. I've attached a couple of pics to show.
    You must have a special phone! That's it I'm doing no more battery pulls haha.
    I'm still on JB but I doubt that has much to do with it.
    Interesting that it happened though. I'm surprised that you got such a big difference (a few percent I wouldn't really be suprised) but 16% is a lot. Has it happened more than once?
    Lucky sod! (Kidding :-))
    Sarks.
    Sent from my SM-N900V using AC Forums mobile app
    Attached Thumbnails Attached Thumbnails Battery jumps 16% after I did a battery pull-1400573349757.jpg   Battery jumps 16% after I did a battery pull-1400573411975.jpg
    dpham00's Avatar
    Posts
    Global Posts
    24,790 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yes it has happened more than once. I think I saw a 20% increase once
  5. #5
    anon8380037's Avatar
    Posts
    Global Posts
    5,210 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I eventually saw it on the battery monitor app screens history. You sure it was showing 29% before the pull on the stock battery indicator.
    I would hazard a wild guess that -
    1. the temperature dropped roughly a small 5 degrees in the 2 minutes out, and a battery apparently charges quicker and takes a higher percentage of the max amp when cool,
    2. I would think the app is not reading it correctly for a while when put back, but is not geared to correct itself.
    You always run that phone hot!
    Sent from my N9005 using Tapatalk Pro
    dpham00's Avatar
    Posts
    Global Posts
    24,790 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Madd54 View Post
    Yeah my phone gets hot.
    anon8380037 likes this.
  1. Galaxy S5 Battery Drain
    By roy862014 in forum Samsung Galaxy S5
    Last Post: 05-06-2015, 08:25 AM
  2. Replies: 120
    Last Post: 08-05-2014, 02:38 PM
  3. Gear 2 vs Neo = Why did you decide on which one to buy.
    By kh4fun in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-26-2014, 09:29 PM
  4. Battery differences and useages.
    By droidntn in forum Samsung Galaxy S4
    Last Post: 05-24-2014, 05:24 PM
  5. My samsung s3 won't open after the update
    By Emily Emy in forum AT&T Galaxy S3
    Last Post: 05-19-2014, 06:48 PM
