Results 1 to 7 of 7
    Default Annoying reboot issue
    So I'm experiencing a highly annoying issue with my phone rebooting....
    It's happened on my last 3 runs. I use an app called Sports Tracker while running to measure time and distance, listen to music via a pair of Bluetooth headphones, and use the galaxy gear to control the music. I don't know if the combination of these things is simply too much for the note to handle, but about half an hour to 40 minutes into my last 3 runs the music stops. Using the home or power button will not get the screen to wake up, and after about 3 minutes the phone just reboots itself. Incredibly annoying because all the data from my run is lost.
    Anyone else had any kind of issue like this? Unfortunately I think I'm heading down the factory reset road.... which seems like a pain, but is probably a better option than smashing the phone into tiny little pieces....
    Sent from my SM-N900V using AC Forums mobile app
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Annoying reboot issue
    Quote Originally Posted by kj11 View Post
    Before trying the factory reset, I'd wipe the cache partition in recovery mode. Saves you from all of the trouble of reinstalling and setting everything up and it doesn't hurt to try
    kj11 likes this.
    Thanks, and I should have mentioned that I did that on Monday and it happened again this morning
  4. #4
    My random reboots were due to a case that was too tight.
    Notes from Deb's Note 3
  5. #5
    If you have a SD card, try removing it to see if a faulty card might be causing your phone to reboot.
    kj11 likes this.
    Quote Originally Posted by ShaggyKids View Post
    That's interesting. No case here though....
    Quote Originally Posted by Baby_Doc View Post
    I was going to try leaving the gear at home first, but this makes sense I think. I can use Google play for the music. Thanks, good idea
  1. Kitkat roms without charging and brightness issues
    By Skip Furrer in forum Hisense
    Last Post: 06-24-2014, 04:18 PM
  2. Calendar/Date Issue
    By Anthony Greseth in forum Motorola Droid MAXX
    Last Post: 05-22-2014, 11:37 AM
  3. Yahoo Weather issue on Z2
    By kulvershtukas in forum General Help and How To
    Last Post: 05-21-2014, 06:45 PM
  4. S finder issues
    By Daktor in forum Samsung Galaxy Note 3
    Last Post: 05-21-2014, 03:02 AM
  5. stock texting app issue
    By monicajae in forum Samsung Galaxy S5
    Last Post: 05-20-2014, 07:30 PM
