1. the tall guy's Avatar
    Hi - I was lucky enough to get my hands on an S5 a couple of weeks back through a competition, so far I'm loving the phone, but someone is offering to swap me a Note 3 plus a Gear watch for the S5. What should I do people? I loved my Note 2 last year and I'm not due an upgrade until Oct this year so I'll have my pic when its time. I just need to make the choice.... S5 or Note 3 until Oct?
    05-22-2014 03:53 AM
  2. dkhmwilliams's Avatar
    I have the Note 3 so I'm biased. I think that it is the best smartphone on the planet. I like the size of it and the S-pen functionality has been a great experience. If you used the S-pen often with your Note 2 then I say you should swap for the Note 3 and then upgrade to the Note 4 when you are eligible.
    Sent from my Note 3. It has a pen😉
    05-22-2014 04:34 AM
  3. jpr's Avatar
    I would definitely go with the Note 3 and Gear but you know these questions are always subjective. I have nothing against the S5 except it doesn't have an S-Pen. Well depending which carrier you're on it may also only come with 16GB internal storage, which I wouldn't like either, but that may not be true with yours.
    Since you've used a Note 2 before and you already have the S5 you should have a pretty good idea of what you'd like better. Throwing in the Gear watch, assuming you'd use it, it seems like a no brainer to me. But if you don't care about the S-Pen and you like the smaller size and slightly newer hardware of the S5, I doubt you'd be unhappy with it for 5 months.
    The only thing I would prefer about the S5 myself is the water-proofing. That alone is not enough to get me to choose it over the Note 3.
    Just editing to add that this was based solely on a phone comparison, not on whether or not it's wise to swap phones with someone else. You didn't state the circumstances of the swap. If you're taking about swapping with someone online, I'd run from that and hold on to your S5. If you're talking about swapping with a good trustworthy friend or relative, go for it.
    05-22-2014 04:35 AM
  4. the tall guy's Avatar
    Thank you both - I think I already knew my answer, I just needed a little persuading. I did use the S Pen on the Note 2 and loved it, so I think I'll do the swap. I currently use the Sony Smart Watch 2 and enjoy its novelty, so the Gear being thrown in as well is a great offer. The swap is with a close friend so I know I can trust him.
    johnmltb33, jpr and Spencerdl like this.
    05-22-2014 05:06 AM
  5. dc52ltr's Avatar
    GS5->Note 3+Gear->Note 4 when you`re due your renewal...sorted!
    anon8380037 and the tall guy like this.
    05-22-2014 05:54 AM
  6. jeepmanjr's Avatar
    My wife has the S5, I have the N3. I would never trade, I love my N3. In fact, I haven't found a single thing I don't like about it (except OTAing to KK without rooting first - but that's my fault!). She's already complaining about the S5 charging port door and that she wished it came with an S Pen. I'd say go for it! And a Gear watch to boot! Just my .02.
    the tall guy likes this.
    05-22-2014 10:28 AM
  7. ShaggyKids's Avatar
    I think it depends on what's important to you. In my case my note 3 does everything I can think of that I want it to do my big thing is this jumbo screen. I absolutely love it and I don't even wanna go a pinch smaller.
    I've seen pictures of the s5 and my daughter has one and I think it's bigger than the s4 which I did have previously but I still don't think it's a big is a note 3.
    Notes from Deb's Note 3
    05-22-2014 10:56 AM
  8. dontlookatme's Avatar
    Well you are on the note 3 forum. So we are most likely to choose note 3. Now if you didnt post this in any other forum, then it seems like you made up your mind on the note 3. Also if it is the gear 2, then i would change.
    Sent from my SM-N900V using Tapatalk
    05-22-2014 11:00 AM
  9. zeuswsu's Avatar
    It all comes down to if you want the bigger screen or not.
    05-22-2014 02:33 PM
  10. anon8380037's Avatar
    You have made the decision you wanted. You had the Note 2 so it made sense to take the Note 3.
    Personally I really like the new Touchwiz on the S5, though after a similar time, 2 weeks, I would probably regret leaving the Note 3, because of its screen. I don't know.
    We have had this old Touchwiz for at least 3 years, and the Note 3 deserved better.
    I don't think we will ever get it now.
    So if you can get the Note 4 when it comes out as well, you have it made.
    :jealous:
    Sent from my N9005 using Tapatalk Pro
    Spencerdl likes this.
    05-22-2014 03:07 PM
  11. Spencerdl's Avatar
    I have to agree with almost erveryone else in this thread and suggest going ahead with the trade. I had the pleasure (smile) of helping my Sister set up her S5 and to be honest my Note3 was/is a better overall device IMHO. Your also getting the Gear watch (I'm also JEALOUS)....Go for it, I'm sure you be glad you made the trade. SMILE
    anon8380037 likes this.
    05-22-2014 03:27 PM
  12. Jelly Belly's Avatar
    Offer to trade, once they hand over the Note 3 and Gear, run off, then you have both.
    longsock123 likes this.
    05-22-2014 05:42 PM
  13. Rmedy21's Avatar
    It's interesting that you put this topic because I too was thinking of getting the s5. I have had the note 2 and note 3. I love my note 3 I would give up my 32gig just for 8 gigs makes no sense to me.
    05-22-2014 09:14 PM
  14. anon8380037's Avatar
    Are they not 16 or 32gb? I could live with 16gb just. I have 20gb free device storage now on my Note 3 (Shock! - Horror!).
    05-23-2014 09:05 AM
  15. dpham00's Avatar
    S5 is 16gb minimum. I have used up most of the storage on my note 3, internal and 128gb microSDXC.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    05-23-2014 09:28 AM
  16. Rmedy21's Avatar
    The s5 is a 16gig but Samsung only gives you 8 gigs of space on the s5. That's why I won't consider the s5
    05-23-2014 01:40 PM
  17. AlfBriggs's Avatar
    Go Note3 its the best device hands down! Also does your phone run slower when's it's got more storage like insanely slower???
    05-23-2014 02:14 PM
  18. the tall guy's Avatar
    Went and swapped the phone had the note 3 for a few hours now and it's the best swap I've ever done!! its an amazing phone. Can't tell any speed difference between this and the s5
    Spencerdl and anon8380037 like this.
    05-23-2014 02:23 PM
  19. anon8380037's Avatar
    http://img.tapatalk.com/d/14/05/23/nuba8uju.jpg
    Hey, my Storage doesn't display a breakdown anymore. Is that another KK change.
    Don't you get 'insufficient storage' warnings?
    Well dpham00, I would hold onto that last 45mb, you might need it, ya never know.
    05-23-2014 02:38 PM
  20. jpr's Avatar
    Hey, my Storage doesn't display a breakdown anymore. Is that another KK change. ....
    I don't know if this is what you mean since I never had JellyBean on this phone. But you can get a further breakdown if you click on Used Space and Miscellaneous Files.
    05-23-2014 02:57 PM
  21. dpham00's Avatar
    That is incorrect, at least for retail versions which should have around 10.7gb free.
    The demo version which Samsung used at their event had 8gb free, due to additional promotional materials on the device.
    05-23-2014 03:10 PM
  22. dpham00's Avatar
    http://img.tapatalk.com/d/14/05/24/e4e7anuq.jpg
    I have on both internal and sd. I have to go through and delete some stuff from time to time.
    05-23-2014 03:13 PM
  23. anon8380037's Avatar
    Yes. I was sure I had tried opening each one, but there it is now. This is a different layout to dpham00's screen on JB, and what I was used to.
    Pity Samsung didn't give us a list of what changes from JB, I guess too much cost involved.
    05-23-2014 03:59 PM
  24. Rmedy21's Avatar
    @Dpham00 Thanks for clarifying. I went to the Verizon store and I saw that the S5 had only 7 gigs of space. It is because it's a floor model?
    05-27-2014 02:00 PM
  25. dpham00's Avatar
    Yes it is the floor model. The consumer model should have around 10-11gb free.
    05-27-2014 02:35 PM
  1. Phone on or off when charging?
    By tonyr6 in forum Google Nexus 5
    Last Post: 10-02-2015, 03:28 AM
  2. Transfer my S4 memo in to S5 from Kies..remains unresolved
    By Surend ran in forum Samsung Galaxy S5
    Last Post: 07-11-2014, 09:26 PM
  3. Replies: 0
    Last Post: 05-22-2014, 01:32 AM
  4. GS4 Bluetooth stays paired, but won't keep "use phone audio" on
    By emkayca in forum Samsung Galaxy S4 Accessories
    Last Post: 05-22-2014, 12:19 AM
