05-30-2014 07:17 PM
30 12
tools
  1. AlfBriggs's Avatar
    I'm a heavy user of my Note3 and today I got 8 hours screen on time and I'm still on 22% I'm no light user I'm constantly pushing my phone I left my home with 96% this morning the time was roughly 8.25am I've been playing NSS all day (soccer battery consuming game) been generally whizzing around the phone and my shock I can't crack it I'll admit it the last two hours I've been in low brightness power saving mode however it's still amazing - I think it may be something to do with a CPU and RAM app I downloaded which shuts app when you lock the phone and shuts any apps taking up lots of ram it also gets rid of junk files eg cache which I had tons of. The app is Clean Master it rules I also downloaded Battery Doctor which helps - I'm undecided between Battery Widget Reborn or Battery Doctor! But anyway I'm loving my Note3 experience of course I won't always be able to have the brightness down especially in bright areas as that screen goes ridiculously dim. I believe it's 2 knits which is frightening.
    05-23-2014 06:02 PM
  2. FBA's Avatar
    Nope, shutting down apps and cleaning RAM doesn't give you better battery on this phone. Android likes its RAM full...and likes having apps open, so it takes less power to get back to running apps. I have Clean Master...and it's basically nothing more than "clear RAM" in the native active apps widget.
    05-23-2014 06:35 PM
  3. Isc73's Avatar
    I get max of 4 and a half hours screen time in a full day. However, I usually get around 3 and a half, because I sometimes play half an hour to an hour on HOC (Online 3d game) still want a ton more battery life, how do you do it!!!
    Sent from my SM-N900T using Tapatalk
    05-23-2014 08:31 PM
  4. jpr's Avatar
    He has a Neo - screen, among other things, should use significantly less battery than ours. And it has a 3100mAh battery despite that.
    05-23-2014 08:43 PM
  5. vpblaze's Avatar
    8 hours! Wow!!! I used to get 6 hours when I was on JB, lucky if I get 5 now that I am on KK. I wish I could get 8 hours.
    Scribbled on my Note 3 then magically translated into readable words using Tapatalk
    05-23-2014 09:45 PM
  6. FBA's Avatar
    He's lying. See his other thread about battery life.
    05-23-2014 10:32 PM
  7. vpblaze's Avatar
    Darn..... That's kind of a downer... I was hoping that he had some super cool $100 app that I could have downloaded to get 8 hours screen time.
    05-23-2014 10:57 PM
  8. AlfBriggs's Avatar
    Actually I charged my battery back up again and this happened.
    05-24-2014 05:42 AM
  9. FBA's Avatar
    12 hours of screen-on time in two charge cycles, and a full 2 1/2 hour charge, all in in 11 hours? Really? How's that physically possible?
    emad1995 likes this.
    05-24-2014 06:08 AM
  10. AlfBriggs's Avatar
    Two different people two phones - Jesus thanks for stalking me for the past 2 days as well.
    05-24-2014 04:06 PM
  11. FBA's Avatar
    2 different people on the same board with the same name and the same post count right?
    05-24-2014 05:23 PM
  12. emad1995's Avatar
    FBA you crack me up 😂
    anon8380037 and Spencerdl like this.
    05-24-2014 06:03 PM
  13. FBA's Avatar
    Well, I just couldn't resist...and apparently, I'm a stalker now too!!!
    05-24-2014 11:35 PM
  14. Aquila's Avatar
    Unless you're trying to troubleshoot a specific wakelock or similar issue, I'd get rid of the battery saving and RAM clearing and task killing apps. As indicated earlier, those are going to be more detrimental than beneficial to both performance and battery life.
    05-25-2014 09:32 AM
  15. Golfdriver97's Avatar
    I would like to see some screen shots of the battery stats and the graph please.
    From a Slim M8 and the AC Forums app.
    anon8380037 likes this.
    05-25-2014 10:16 AM
  16. Relgoshan's Avatar
    I just want the trolls to stop marketing fake battery optimizers in device subforums. There's areas for that stuff, use them.
    05-25-2014 03:33 PM
  17. thegame161's Avatar
    05-26-2014 11:35 AM
  18. Relgoshan's Avatar
ID:	120060Click image for larger version.
    Well, that's definitely low brightness at work there. And the Android System power usage is *miles* too high.
    05-26-2014 11:40 AM
  19. thegame161's Avatar
    Nah its on auto. It's only looks really low due to it always being lower when under 5%
    Android system is always higher since updating to kitkat. It tends to be at times over 28% some days.
    05-26-2014 11:44 AM
  20. emad1995's Avatar
    One time I had 3h 30 min screen on with auto brightness, and my android system was using 39% battery while screen was using 22%. KitKat has some battery drain issues :E
    05-26-2014 12:09 PM
  21. anon8380037's Avatar
    I think @Golfdriver97 was asking the OP for battery screenshots with the usage graph.
    Sent from my N9005 using Tapatalk Pro
    Golfdriver97 likes this.
    05-26-2014 01:24 PM
  22. Relgoshan's Avatar
    Wow, that's a terrible regression. My Android System is 4% not 25-40%. I am 64% battery after 24hrs off the mains on my Flex. When it first came out the Note 3 had good battery and one of the best screen-on times too, this KK....wait. Did you factory reset after Kit Kat? Or not? I keep hearing it makes a big difference on some phones.
    05-26-2014 01:25 PM
  23. thegame161's Avatar
    I never did that as I havnt needed to really. Even though Android system is a lot higher on kitkat battery life is still great so hasn't been an issue to me. Not sure why it's higher on kitkat but as I said I get on average 5 hours screen time and well over a day+ total
    05-26-2014 01:44 PM
  24. Aquila's Avatar
    It might just be a change in the categorization of certain tasks and/or a different methodology of executing similar functionality that is handled by the OS instead of a separate app, etc.
    05-26-2014 01:53 PM
  25. Ro Klei's Avatar
    I don't fully get all this battery talk about the note3, I'm very happy with my battery time and am on kk or 4.4.2, I tend to charge my note3, either once a day or once every 2, sometimes even 3 days depending on what I do with it, today, this morning rather, I think I woke with 88% on batterry, last charge was sometime yesterday eve, but either way I thought it did ok streaming 5 to 6 hours of youtube constant before the 15% window poped up...love the phone and it's ridiculously long battery life...
    05-26-2014 02:04 PM
30 12
  1. Verizon Galaxy Note 3 Battery Life Poor on KitKat
    By music_man185 in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-13-2015, 12:41 AM
  2. note3, 10000mah zerolemon- case options?
    By netman86 in forum Samsung Galaxy Note 3
    Last Post: 06-10-2014, 11:22 AM
  3. Replies: 22
    Last Post: 06-03-2014, 01:00 PM
  4. Note 3 battery
    By Isc73 in forum General News & Discussion
    Last Post: 05-25-2014, 08:44 AM
  5. GALAXY S3 i9300 (INTL) Battery Charger, Voltage And System Issue
    By Salvator101 in forum Samsung Galaxy SIII I9300
    Last Post: 05-24-2014, 03:27 PM
