1. AlfBriggs's Avatar
    Im located in the UK and I've always wondered about 4G I'm on Three UK now you Americans might believe EE is the best and biggest and certainly your right about the biggest however Three is a lot faster than my friends 4G, Three is suppose to be superfast and my god it is my pages load in 1-6 seconds depending on flash and my BBM send time is milliseconds. I'm very happy however since I'm running on 3G (well HSPA+ it says) how much faster will 4G be when it arrives because I may live in a City but Three has only just started the rollout with the major London and Manchester areas the only connected, so how much faster will 4G be?
    05-24-2014 05:50 AM
  2. dpham00's Avatar
    It depends on the configuration, and other things like signal and load. I don't know what is being deployed, but peek lte speeds can range from 37.5mbps on 5x5 up to 150mbps on 20x20mhz on fdd. Tdd, I believe maximum right now is 63mbps.
    This is for a single carrier. Combining carriers known as carrier aggregation can get faster speeds, although current devices see category 4,so maximum for now is 150mbps anyway. Probably next year, cat 6/7 devices will come out supporting 300mbps through lte-a with carrier aggregation.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
    AlfBriggs likes this.
    05-24-2014 08:56 AM
  3. Almeuit's Avatar
    Below is a speed test running HSPA. The next is LTE.
    Sent from my T-Mobile Note 3 using AC Forums.
    Attached Thumbnails How much faster is 4G LTE?-1400961518067.jpg   How much faster is 4G LTE?-1400961527817.jpg
    05-24-2014 02:58 PM
  4. AlfBriggs's Avatar
    Impressive very big increase where are you located may I ask?
    05-24-2014 04:04 PM
  5. Rick Bell's Avatar
    My speeds here in Fayetteville, Ark, USA
    Posted from my VZW LG G3
    09-26-2014 08:27 PM
  6. ffejjj's Avatar
    4g is the bees knees
    09-26-2014 08:43 PM
  7. dpham00's Avatar
    This is the fastest I have gotten on LTE.
    09-27-2014 12:04 AM
  8. clevin's Avatar
    my H+ is around 10mbps, LTE is around 20-30mbps.
    yes LTE is faster, but is it necessary? no. I don't see anything on a mobile device that "requires" 30mbps network speed, unless you are download GB sized files all the time.
    in short, LTE is faster, and faster is always nice, but its not something that swept me off the ground.
    09-27-2014 04:53 AM
  9. dpham00's Avatar
    When I used t-mobile, 4g was around 1-3mbps at home and at work. 4glte was around 35mbps.
    09-27-2014 11:41 PM
  1. Will 4G function globally?
    By Trebby123 in forum HTC One M8
    Last Post: 05-26-2014, 03:56 AM
  2. How to upgrade to Kitkat
    By roni09riku in forum Android 4.4 KitKat
    Last Post: 05-25-2014, 09:51 AM
  3. How to not allow apps to be installed on sd card
    By majdi suliman in forum Samsung Galaxy S4
    Last Post: 05-24-2014, 12:58 PM
  4. How do I mark email as spam on an S5
    By JClintB in forum Samsung Galaxy S5
    Last Post: 05-24-2014, 04:56 AM
