Nothing the other people use low brightness power saving mode and are probably either lying or insane if they say they get more than six hours also what font is that and another note most users with good battery life are on 4.3 like me
Firstly, I don't think it's right that you accuse the people here of lying. There may be a small portion of people here who will lie about their battery life etc but the large majority of people on here are honest and helpful. You yourself should know this from the postings you have created in the few weeks that you have been a member.
Secondly, it is possible to have good battery life and screen on time. I'm posting a screen shot of my battery life from gsam which has monitored my battery life for the last 6 wks or so. It shows my average battery life is 20 hrs 9 mins with 7 hrs 10 mins of screen on time.
Also including screenshots of my battery life right now. I'm close to what the original poster has in terms of battery and screen on times yet I still have over 40% of my battery life left.
Original poster - if I were you I would also monitor what is running in the background which may be keeping your phone awake (such as the social media apps you have running) and draining the battery.
As for my screen brightness etc - my brightness is set to about 20-25% when inside and when I am outside (san diego - lots of sun) I put it up to about 55-65%.
I don't use the power saver mode - tried it and didn't like it, plus I get good battery life so I really didn't need it.
I don't use facebook, etc but I do have Whatsapp and I have 8 email accounts all set to push. I have gps/location, wifi, data on all the time, as well as nfc, air view, sync, and sbeam.
I find the screen on time on gsam vs settings>>battery>>screen to be pretty much the same ...usually just a few minutes of difference.
I'm sure others will give you more advice on things to try so you can improve your battery/screen time.
Sarks.
