08-01-2014 01:24 AM
40 12
tools
  1. ehsan_3's Avatar
    Hi all. I see people reporting 6 hours of screen on time for their note 3 with heavy usage. But i find myself in a much different position with my sm n900. If i dont enable the power saving mode, i feel lucky to reach 4 hrs 30 mins of screen time. Screenshots were taken with power saving mode enabled. Brightness is half (auto). I use wifi at home, and 3g when I'm out. The wifi and 3g usage per day is almost equal. The phone is unrooted and stock running kitkat with touchwiz, no useless apps. I have a few games, email and mostly social networking apps (facebook, twitter, ig, bbm, whatsapp, snapchat, tinder, bitstrips).
    What am i doing wrong? And please, i don't wanna reset my phone. Is there any other solution? Thanking you all in advance.
    Attached Thumbnails Note 3 battery issues-screenshot_2014-06-01-23-26-28.jpg   Note 3 battery issues-screenshot_2014-06-01-23-26-38.jpg
    Jalopiejoe likes this.
    06-01-2014 01:38 PM
  2. AlfBriggs's Avatar
    Nothing the other people use low brightness power saving mode and are probably either lying or insane if they say they get more than six hours also what font is that and another note most users with good battery life are on 4.3 like me
    06-01-2014 03:58 PM
  3. FBA's Avatar
    The system is very inaccurate as far as screen-on time reporting goes. 6 hours of screen-on time isn't really attainable for the most part, unless you run at 5% screen brightness.
    If you really want to be sure how accurate the reporting is, test the screen-on time manually, and compare against the system. GSAM has the same inaccuracies, probably because it reports from the Android system, same as the native battery app. I did some testing and found it to be way off...
    anon8380037 likes this.
    06-01-2014 05:19 PM
  4. ehsan_3's Avatar
    I'm using samsung sans font, size set to tiny. Looks professional.
    So i believe my battery life is normal. Is there a way to downgrade to jb? Note 2 was a beast when it came to battery life.
    06-01-2014 10:07 PM
  5. ehsan_3's Avatar
    It's sad how android central users lie about their screen on time. We are here to help people, not to confuse them.
    I've installed gsam and I'll post a screen shot after a full day's use, for you guys to see.
    06-01-2014 10:09 PM
  6. zero bim's Avatar
    I think you are not right to accuse others of lying. We just based on the values given by the system stat and posted the results here for others benefits.
    sarkycow likes this.
    06-01-2014 11:02 PM
  7. ehsan_3's Avatar
    But how are people reporting 8 hours of screen time with heavy usage? That's not even possible.
    06-01-2014 11:05 PM
  8. zero bim's Avatar
    Why is it not possible? I consistently get 7+ hours of screen time over a 24 hours period using lte. I can get 6+ hours over 48 hrs.
    I have quite a lot of widgets too. The only thing I have off are google now and location reporting and history set to off (but location service is still on using wireless only). Also I have "scan ...using wifi" in wifi advanced setting to off.
    ehsan_3 and sarkycow like this.
    06-02-2014 01:34 AM
  9. ehsan_3's Avatar
    I apologize for being offensive. I Did everything you mentioned. Let's see how it goes. Thanks.
    06-02-2014 02:21 AM
  10. ehsan_3's Avatar
    I definitely see some improvement after disabling the features that you mentioned. Getting to 1 hr screen time within the first 10% was a big deal for me prior to posting this thread.
    Attached Thumbnails Note 3 battery issues-screenshot_2014-06-02-14-32-04.jpg
    06-02-2014 04:35 AM
  11. sarkycow's Avatar
    Firstly, I don't think it's right that you accuse the people here of lying. There may be a small portion of people here who will lie about their battery life etc but the large majority of people on here are honest and helpful. You yourself should know this from the postings you have created in the few weeks that you have been a member.
    Secondly, it is possible to have good battery life and screen on time. I'm posting a screen shot of my battery life from gsam which has monitored my battery life for the last 6 wks or so. It shows my average battery life is 20 hrs 9 mins with 7 hrs 10 mins of screen on time.
    Also including screenshots of my battery life right now. I'm close to what the original poster has in terms of battery and screen on times yet I still have over 40% of my battery life left.
    Original poster - if I were you I would also monitor what is running in the background which may be keeping your phone awake (such as the social media apps you have running) and draining the battery.
    As for my screen brightness etc - my brightness is set to about 20-25% when inside and when I am outside (san diego - lots of sun) I put it up to about 55-65%.
    I don't use the power saver mode - tried it and didn't like it, plus I get good battery life so I really didn't need it.
    I don't use facebook, etc but I do have Whatsapp and I have 8 email accounts all set to push. I have gps/location, wifi, data on all the time, as well as nfc, air view, sync, and sbeam.
    I find the screen on time on gsam vs settings>>battery>>screen to be pretty much the same ...usually just a few minutes of difference.
    I'm sure others will give you more advice on things to try so you can improve your battery/screen time.
    Sarks.
    Attached Thumbnails Note 3 battery issues-screenshot_2014-06-02-04-16-00.jpg   Note 3 battery issues-screenshot_2014-06-02-04-15-42.jpg   Note 3 battery issues-screenshot_2014-06-02-04-15-35.jpg   Note 3 battery issues-screenshot_2014-06-02-04-15-30.jpg
    06-02-2014 06:32 AM
  12. FBA's Avatar
    At all of you who think they're getting screen on time of 6+ hours. Your data is inaccurate and all you do is propagate bad data that by posting those screen shots.
    Test it manually and MANUALLY document the screen-on time. You will be amazed at how wrong those numbers actually are.
    Install an app that will keep your screen on all the time and watch how fast the battery dies.
    The phone doesn't run 24 hours with 6 hours of screen on time...and if you bother to test, you'll see that for yourself.
    Some simple math using the data in the screenshots above proves that.
    06-02-2014 06:44 AM
  13. ehsan_3's Avatar
    Sarks.
    Were these stats captured after a full charge or a top up? And i am sorry for my baseless accusation.
    06-02-2014 06:59 AM
  14. ehsan_3's Avatar
    So do you mean some phones that have this bug show 6+ hours of screen time, and uninfected phones show the correct time i.e 4-5 hours.
    06-02-2014 07:01 AM
  15. sarkycow's Avatar
    I have tested it manually as I wanted to compare the battery life versus the manual tests I did when I had my iPhone 4S before the note 3. I've also documented my iPad and my husband's note 8, not that they're relevant in this discussion.
    I keep an Excell spreadsheet I have kept timing once a week since Sept. when my husband and I got our Note 3s. I also want continue this when im on kitkat to see if there is a major/minor difference.
    06-02-2014 07:11 AM
  16. sarkycow's Avatar
    This was from a full charge. If it had been topped up you would see it on the screen shot with the bar graph - at the bottom where it says charging there would be a green line if someone had topped up.
    Hopefully that makes sense - it's 5 am here.
    Sarks.
    06-02-2014 07:15 AM
  17. ehsan_3's Avatar
    There you said it, the only difference is the os. Before kitkat, i was easily getting 6 hrs, but now it is impossible. My advice, don't upgrade to kitkat. And good night, or morning?
    06-02-2014 07:19 AM
  18. sarkycow's Avatar
    My husband upgraded to kitkat and he hasn't noticed much difference - but he seems to be one of the lucky ones, many on here (like yourself I guess) have had big changes mostly for the worst.
    I'm going to avoid it for as long as I can - but I'm sure one morning I'll wake up and it will be installed for me
    I know you don't want to reset but I've seen (on here) plenty of people benefiting from it after updating it to kitkat. I just think it's crap that they don't give us a choice to keep JB.
    Good luck!
    Sarks.
    06-02-2014 07:30 AM
  19. FBA's Avatar
    @ Sarkycow -
    Please help me understand, and since you have all the data in Excel, plus manual testing, you should have the answer!
    Your screenshot indicates the phone having been on for 9 hours 43 minutes and 59 seconds since last full charge.
    You are at 53% used on this battery
    You show 37% screen usage, which equates to about 3.59 hours of screen-on, yet you show 5 hours 6 minutes and 30 seconds of screen-on.
    Can you explain that so I understand?
    You have tested manually, where you leave the screen on idling for the whole time until the battery dies? How long did the charge last?
    When I turn the screen on, and do nothing - in other words, I don't touch the phone at all...actual screen on time works out to less than half of what is reported by Android or GSAM.
    06-02-2014 09:38 AM
  20. ehsan_3's Avatar
    I did as zero bim said, and the results have been good so far. But then, i didn't leave home today so i was connected to wifi the whole time. I've noticed that 3g kills the battery.
    I had to restart the phone, that might have effected the stats in gsam.
    This is with power saving mode enabled and apex launcher.
    Attached Thumbnails Note 3 battery issues-screenshot_2014-06-02-19-56-21.jpg   Note 3 battery issues-screenshot_2014-06-02-19-56-26.jpg   Note 3 battery issues-screenshot_2014-06-02-19-56-45.jpg   Note 3 battery issues-screenshot_2014-06-02-19-56-52.jpg
    06-02-2014 10:02 AM
  21. FBA's Avatar
    It's not 3G killing your battery - it's 4G LTE. You can read all over the web how LTE eats battery...
    tankdog03 likes this.
    06-02-2014 10:06 AM
  22. ehsan_3's Avatar
    I have the 3g variant of note 3. So no lte for me. Sm-n900.
    And we don't have lte where i live.
    06-02-2014 10:13 AM
  23. anon8380037's Avatar
    Sarks.
    Well spotted Sarks.
    Personally I have given up on percentages and screen time stats. I DON'T want my phone to last 2 days and 10 hours screen time. I would like it to last a hard day with a reserve. Anything else is a bonus. I don't work my phone hard but use a lot of screen time browsing etc.
    I am currently working on a half baked theory that leaving my SD card out for the last 3 days has dramatically improved the early drain from 100% and over the day in general. I also had done a 1st factory reset before that, but I left the card in for another day and the battery seemed as before then.
    In the 3 months since KK my battery has generally been OK, save for the last 2 weeks where it was dropping badly and I was doing top ups.
    Then I started getting sd card 'unexpectedly removed' notifications hence the reset and card pull. The card data is still fine. I haven't ordered another card yet. I now have 23.5gb device storage left. I had 20gb free prior to reset.
    So I can move my 10 gb of sd music and photos there no problem. I had many apps on the card all working, but depending on the new card I may leave them on the device.
    Anyone see the post in Verizon I think where a store told the poster that class 10 cards were too fast, and a lower speed card cured the problem. Another myth perhaps, but I read that on Amazon last year. My card that failed after a year on two phones was a 16gb class 4.
    This was mean to be a short post, sorry!
    Sent from my SM-N9005 using Tapatalk Pro
    06-02-2014 11:01 AM
  24. FBA's Avatar
    I understand. 4G LTE is even more brutal on battery!
    06-02-2014 11:12 AM
  25. FBA's Avatar
    Well spotted Sarks.
    So anyone claiming a lower speed card would reduce drain would be very wrong, but this is after all, the Internet! I do however believe that apps working from an SD card would be a more significant drain on battery, since external memory is slower than internal and requires more effort to read/ write.
    I'm curious though as to whether your device battery life has improved with the card out! I don't use my SD card anymore...I load everything to memory and use Google Drive Sync to move the data up to Google drive.
    I don't need more than 5-6GB of memory, so in my case, the SD card doesn't do anything for me and backing up to the cloud gives me the data integrity I was looking for.
    If I can save battery by removing the SD card, it's free battery life.
    06-02-2014 11:17 AM
40 12
  1. Replies: 3
    Last Post: 06-12-2014, 07:09 AM
  2. Nexus 7 (2013) Why does the google app use so much of your battery?
    By Terrorizer in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-03-2014, 04:54 PM
  3. Note 3 fo Dummy's Book
    By mickeyboat in forum Samsung Galaxy Note 3
    Last Post: 06-01-2014, 07:19 PM
  4. S Note sync does not work
    By 7tomek7 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-01-2014, 01:47 PM
  5. Battery problem?
    By Rolomoto in forum Motorola Droid X
    Last Post: 06-01-2014, 01:31 PM
