Results 1 to 7 of 7
    Default Unexplained Battery Drain
    Basically it was steady then dropped dramatically and kept going but then as soon as I start using it again like with screen on the battery is fine like going down slow screenshots attached.
    Attached Thumbnails Attached Thumbnails Unexplained Battery Drain-screenshot_2014-06-19-17-42-55.jpg   Unexplained Battery Drain-screenshot_2014-06-19-17-42-49.jpg   Unexplained Battery Drain-screenshot_2014-06-19-17-42-39.jpg
  2. #2
    jeepmanjr's Avatar
    Posts
    Global Posts
    55 Global Posts
    Default Re: Unexplained Battery Drain
    Hey Alf, have you tried any of the battery monitoring apps? If you're experiencing poor battery performance it's got to be one of two things. Either you have apps/hardware that are sucking it dry or you have a bad battery (or you're a phone using maniac!! LOL). Personally, I use GSam. Gives me a lot of good information about battery use. After a little tweaking I now get great battery life. Just checked my phone and per GSam, after 1h 18m I'm still at 99%. Yeah, I only sent a couple of texts and made one short phone call, but that's still pretty good by my standards.
    Yeah I've tried I've only got a few launchers Facebook Twitter Instagram Snapchat and Plume installed should I delete the unused launchers will they be using battery even if I'm using TouchWiz.
  4. #4
    Quote Originally Posted by jeepmanjr View Post
    All that app tells me is android system is using a lot.
    Attached Thumbnails Attached Thumbnails Unexplained Battery Drain-screenshot_2014-10-16-22-50-35.jpg
  6. #6
    instagram is a notorious battery killer. make sure you swipe it away or stop the program when not in use. also check if your sync icon is on. that will drain your battery too.
  7. #7
    Here is today's battery.
    Is this worst than your battery lives?
    I don't know how long this phone typically lasts for anybody else.
    "I have an American Bassbort!"
    Attached Thumbnails Attached Thumbnails Unexplained Battery Drain-screenshot_2014-10-19-04-31-34.jpg   Unexplained Battery Drain-screenshot_2014-10-19-04-31-26.jpg
  1. VZW HTC One Owners, How's Your Battery Life?
    By A895 in forum Verizon HTC One
    Last Post: 06-27-2014, 07:32 PM
  2. Just spitballing about battery life here.
    By teleburst in forum Samsung Galaxy Note 3
    Last Post: 06-26-2014, 08:44 AM
  3. Galaxy S3 Battery Drain after 4.4.2 update
    By mattg43 in forum Ask a Question
    Last Post: 06-21-2014, 07:44 AM
  4. new Galaxy S4 mini, battery doesn't get me through the day...
    Last Post: 06-19-2014, 02:31 PM
  5. more battery issues
    By acclaim99 in forum Samsung Galaxy S5
    Last Post: 06-19-2014, 01:37 AM
