1. TechnoMichael's Avatar
    I've had my note 3 for about 2-3 months and as soon as I got it I updated to kikat, now my battery is bad, Android system takes up a chunk of it, I wipe the system cache partition many times, I disabled certain apps that might drain it but nothing works,I don't want to do a factory reset, plz help
    Attached Thumbnails Sprint galaxy note 3 battery drain-screenshot_2014-06-19-14-43-22.jpg
    06-19-2014 01:47 PM
  2. jeepmanjr's Avatar
    I've read multiple times that a factory reset may, indeed, improve battery life after the KK update. This has been addressed quite a bit, but have you tried any battery monitoring apps to see why your batt performance is not up to par? I like and use GSam, but there are others.
    06-19-2014 03:06 PM
  1. s4 sprint to verizion
    Last Post: 06-22-2014, 11:49 AM
  2. Galaxy S3 will not load past Samsung Galaxy S3 logo
    By erkf4975 in forum Ask a Question
    Last Post: 06-20-2014, 09:20 AM
  3. Note 2 will not turn on / charge
    By danielions in forum Samsung Galaxy Note 2
    Last Post: 06-19-2014, 08:28 PM
  4. Rooting Samsung Galaxy s4 mini
    Last Post: 06-19-2014, 01:30 PM
  5. Mobile network drained too fast
    By Depress in forum Samsung Galaxy S5
    Last Post: 06-19-2014, 12:46 PM
