Results 1 to 5 of 5
    Default Can't understand why Android system is using 30% of my battery
    Just makes no sense. Can't quite work why it's using so much.
  2. #2
    Default Re: Can't understand why Android system is using 30% of my battery
    Try a reboot and see if it helps for tomorrow. Might be a wake lock issue.
    Sent from my T-Mobile Note 3 using AC Forums.
    Aquila likes this.
  3. #3
    You're on track to get ~5 hrs screen on time. That's pretty good if you ask me. If your screen on time were a lot less then I would be worried.
    Sent from my SM-N900V using Tapatalk
    Well I switched wifi and data off when I went to sleep so I'm at
    2 hours, 5 Mins screen time
    15 hours total
    With 48% left
  5. #5
    Do you have location settings turned on? Google Now? Wifi always scanning?
  1. Replies: 68
    Last Post: 10-25-2016, 10:14 PM
  2. Verizon Galaxy S3 - How can I return to stock?
    By tsawrie in forum Verizon Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 08-28-2015, 09:38 AM
  3. Replies: 30
    Last Post: 01-11-2015, 08:59 PM
  4. Replies: 2
    Last Post: 07-09-2014, 08:48 PM
  5. Do any of you encrypt your Notes?
    By Rubus Roo in forum Samsung Galaxy Note 3
    Last Post: 06-20-2014, 10:14 PM
