1. Closingracer's Avatar
    Only about 1 hour for screen time and music was only played like 30 minutes. This is my first full charge since I updated my phone to the latest with voice over LTE and that download booster.
    Sent from my SM-N900T using Tapatalk
    06-20-2014 07:32 PM
  2. Almeuit's Avatar
    Dang that is pretty bad. Are you in a VoLTE activated city?
    Sent from my T-Mobile Note 3 using AC Forums.
    06-20-2014 07:42 PM
  3. Closingracer's Avatar
    Yeah nyc
    06-20-2014 07:49 PM
  4. jpr's Avatar
    I, and at least a few other people on here, have had better battery life since the update. Have you rebooted and cleared your cache?
    06-20-2014 08:30 PM
  5. Closingracer's Avatar
    I have done a complete factory reset
    06-20-2014 10:17 PM
  6. jpr's Avatar
    Do you have GSAM installed to see if you can get a better idea of what is in use? After you reset, did you turn off WiFi always scanning in the advanced settings and disable any location and Google services that you do not use? Also see if removing your SD card makes a difference. If so, back it up and format it in the phone.
    06-20-2014 10:34 PM
  7. Closingracer's Avatar
    I know it's something wrong with the update
    06-20-2014 10:56 PM
  1. Kit kat update charging issue red X
    By ws6.baker in forum Verizon Galaxy S III
    Last Post: 02-03-2015, 04:54 PM
  2. Replies: 15
    Last Post: 09-16-2014, 10:46 AM
  3. kit kat update s4 mini
    By techiewantabe in forum Ask a Question
    Last Post: 07-06-2014, 09:40 AM
  4. Does moto x have the block mode for text and calls
    By Sergiusz Jasper in forum Ask a Question
    Last Post: 06-20-2014, 07:24 PM
