Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By ShaggyKids
    ShaggyKids's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How to move multi window?
    Is there a way to put multi window on the side of the screen that the user would like it on? Mine was on the left, somehow it wound up on the right and I would like to put it back on the left and don't see an option for positioning it. Thanks.
  2. #2
    Jalopiejoe's Avatar
    Posts
    Global Posts
    661 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How to move multi window?
    Very easy! Tap on multi-window tag then when it moves out , tap and hold tag and drag it to the other side! 😉👌
    Sent from my Samsung Galaxy Note 3
    "Size Does Matter!"
    ShaggyKids's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jalopiejoe View Post
    "Size Does Matter!"
    Thank you! I had to use my pen to do it because my finger wasn't doing the trick but I have it moved now thank you.
    Jalopiejoe likes this.
  1. How to get phone to play through car stereo?
    Last Post: 08-26-2014, 10:32 PM
  2. Replies: 1
    Last Post: 07-12-2014, 02:00 PM
  3. Will the Note 3 be upgraded to Android L?
    By TylerJNelson32 in forum Samsung Galaxy Note 3
    Last Post: 07-04-2014, 08:16 PM
  4. How do I check for free space after uploading songs
    By tech_fan in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 06-27-2014, 08:02 AM
  5. To Root or not to Root.
    By Don Longfellow in forum Ask a Question
    Last Post: 06-26-2014, 09:27 PM
