1. rks959's Avatar
    Hello,I have a note 3 and when i plug in the charger i noticed the light stays on most of the time while its on charge.If anyone has a fix for this i would greatly appreciate it.Thanks,Karey
    07-01-2014 07:09 PM
  2. jpr's Avatar
    You'll have to be more specific. Is the phone screen off or on? What light is showing? If the screen is off the red LED will stay on while charging if you have that checked under LED Indicators in settings.
    07-01-2014 07:45 PM
  3. JimSmith94's Avatar
    My red light stays on while it's charging except when I get a notification.
    Sent from my SM-N900P using Tapatalk
    07-02-2014 04:17 PM
  4. jpr's Avatar
    If anyone wants to completely control their LED you can use Light Flow.
    07-02-2014 04:26 PM
  5. rks959's Avatar
    Hello, Sorry about the lack of information on my question.Phone light stays off while charging but once the battery is fully charged the phone light comes on and stays on,by the phone light i mean the screen light.Thanks for any help.Thanks,Karey
    07-02-2014 05:36 PM
  6. FBA's Avatar
    Now that's not normal. The only light to come on on full charge should be the LED going green...it will be red (if you have chosen that option) during the charging process. The screen should NOT come on from simply charging the phone.
    07-02-2014 07:17 PM
  7. jpr's Avatar
    First, you should not have posted a second thread about this. That's against the forum rules.
    The screen will come on temporarily when the phone reaches full charge. It should shut off again shortly if no input is registered. If it does not shut off by itself, there are three things I can think of.
    You have developer settings turned on with the stay awake while charging box checked.
    You have daydream while charging turned on.
    You have an app that is triggered by the screen turning on that is set to keep the phone awake.
    07-03-2014 12:41 AM
  8. rks959's Avatar
    Sorry about breaking the forum rules,i'll definitely not do it again.Thank you so much for the help.The stay awake while charging box was checked.After i unchecked that, the phone started back working perfectly.I really appreciate the help cause i was really getting concerned about it.Really love this phone.Thanks Again,Karey
    07-05-2014 01:21 PM
  1. HTC One Charging Issue
    Last Post: 09-01-2014, 01:51 AM
  2. Replies: 1
    Last Post: 09-01-2014, 01:10 AM
  3. Bricked, stuck on TWRP
    Last Post: 07-26-2014, 10:23 PM
  4. Galaxy 3 Can't access internet when not on WIFI
    Last Post: 07-01-2014, 05:47 PM
  5. HTC Evo 4g design accidently deleted contacts app and phone app
    By thelastmexican in forum Ask a Question
    Last Post: 07-01-2014, 05:40 PM
