1. KeenAndroid3's Avatar
    Verizon Messages or Textra SMS - which is better replacement for stock SMS (Verizon) ?
    I'm wondering how the features compare on these two top rated stock sms replacements for the Samsung Note 3.
    Denise KC likes this.
    07-05-2014 10:48 AM
  2. KeenAndroid3's Avatar
    After posting this, I see that Verizon Messages in the play store is 40 mb in size, and there are numerous complaints about mssgs not sent, dbl mssgs sent'/rec'd, etc, etc. It seems that the latest update from verizon/samsung adds some features to the existing stock sms, and maybe it's not worth looking at replacement apps now. I don't know.
    07-05-2014 12:08 PM
  3. jeepmanjr's Avatar
    I tried Verizon's offering, I wasn't too awfully impressed. Besides, I already pay Verizon too much as it is. I use the stock app. Free is your friend.
    07-06-2014 09:36 AM
  4. KeenAndroid3's Avatar
    Verizon Messages is free app but with it's size (40 mb) and errors, I will take a pass for now. Stock sms with it's latest updates isn't too bad. I just wish the 'scheduled messages' feature wasn't disabled by Verizon.
    07-06-2014 12:11 PM
  5. z06mike's Avatar
    I use Verizon messages and it works great with no problems whatsoever!!
    Sent from my SM-N900V using Tapatalk
    07-06-2014 11:48 PM
  6. zeuswsu's Avatar
    I use textra and have had zero problems.
    07-07-2014 10:19 AM
  7. Kindie's Avatar
    I use textra as well and love it!
    07-07-2014 04:25 PM
  8. neonworm's Avatar
    Definitely Textra.
    07-07-2014 11:20 PM
  9. KeenAndroid3's Avatar
    Does either textra or verizon mssgs have sms pop up (from lock screen) and 'quick reply' features?
    07-14-2014 05:51 PM
  10. neonworm's Avatar
    Yes. Textra does but I am not sure about the Verizon Messages app.
    07-17-2014 12:40 AM
  11. KeenAndroid3's Avatar
    As a follow up: I have downloaded & installed Verizon Messages+ and found that it also has message popup and quick reply (also over lock screen). It also seems to have more features than Textra (though i have not tested Textra yet). So far i am happy with my choice.
    07-17-2014 09:46 AM
  12. revansCAAD8's Avatar
    Hmmm my Textra doesn't show msg's on my lock screen. Wish it did. Maybe a setting somewhere?
    Posted via my Galaxy Note3 on the Android Central App
    07-17-2014 11:34 AM
  13. revansCAAD8's Avatar
    Can a anyone else with a Note3 and Textra confirm?
    07-18-2014 05:44 PM
  14. KeenAndroid3's Avatar
    Sorry I have not used textra....but I can confirm that Verizon Messages+ in the play store does have a mssg pop up over lock screen, I used it every day. So far no complaints about Verizon Mssages on my Note 3. I love being able to reply to mssgs on my tablet or desktop, also. I didn't think it would be as helpful as it turns out to be. Very nice app so far.
    07-18-2014 05:49 PM
  15. fostermom298's Avatar
    i have be using textra for a while
    07-18-2014 06:45 PM
  16. trucksmoveamerica#AC's Avatar
    I'm using both and I can't get it to show up on my lock screen. I've tried it on stock lock screen and widget locker. The only thing I could get it to do is light the screen up, but it still just showed the lock screen with message icon in notification bar. With widget locker you can have the settings set that you can bring the drop bar down for notification and then tap the message and it will open the message up while lock screen, and I think it leaves in lock screen mode after reading message or replying.
    I for one don't want it to pop up on my lock screen, if it's in my pocket the screen touching my pants/shirt opens the message, closes it out, and all kinds of weird things, if you don't hear the message go off, there's a chance you don't see you got a new message.
    07-19-2014 08:17 AM
  1. gmail app showing unread message
    By Phazeshift in forum Android 4.4 KitKat
    Last Post: 07-05-2014, 10:02 PM
  2. Verizon 4G Moto G?
    By Stephen Spackman in forum Moto G (2013)
    Last Post: 07-05-2014, 10:08 AM
